Old 16-10-2008, 08:49 PM   #1 (permalink)
Debian Gnu/Linux User
Sathish's Avatar
Angry Mac OS X Transformation pack created a problem..Help me.
im using winxp sp3 with KIS 2009..with latest updates.
After i uninstall FlyakiteOSX(mac os transformation pack) last week, i dont see anything when i open administrative tools like services, computer management, etc.. . the particular windows goes to blank..
i have checked with KIS2009 for malwares.. but no detection has been found..
I have no idea about that..
i need urgent help..
Living for Learning & Learning for Living
Sathish is offline
Old 16-10-2008, 09:36 PM   #2 (permalink)
gkbhat.blogspot.com
Default Re: Urgent help needed..
Some of your system files have been corrupted.
repair xp by inserting the installation cd and select repair option "R" when it asks for choice.You will get back your settings.
blogging at http://gkbhat.blogspot.com
gk2k is offline
Old 16-10-2008, 09:42 PM   #3 (permalink)
Sathish's Avatar
i have sp1 xp cd .. is it created any problem while repairing..??
Sathish is offline
Old 16-10-2008, 11:35 PM   #4 (permalink)
Call me Sumit
esumitkumar's Avatar
^^ when u can ctrl evrything as ur siggy says wats the prob dude
jokes apart,Mac OSX transformation pack can mess with sys files sometime ...do what gkbhat says...
esumitkumar is offline
Old 17-10-2008, 12:15 AM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
A very simple solution....... system restore.
ravi_9793 is offline
Old 17-10-2008, 12:16 AM   #6 (permalink)
AFK
thewisecrab's Avatar
Try System Restore as FlyAKite does create a restore point before starting the transformation
Else, do as gk2kbhat says
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 17-10-2008, 12:21 AM   #7 (permalink)
AMD & ATI FANBOY
ultimategpu's Avatar
after system restore -> the files will not completely removed from the system so try out the revo uninstaller --------> that good uninstaller then restart the system ........ dont repair it will alter the files-------------> as u install the sp3 so the files are completely altered with shell32.dll and every runtime files are on the sp3 ---------> so use it with the unistaller
GAMING RIG=>C2DE8500 | ASUS P5Q PRO |3GB DDR 800 |VIEWSONIC VX1932WM|CM 600 WATTS |PALIT 4850
PC RIG=>AMD PHENOM X4 9550 | ASUS MOBO |2GB DDR 667 |CORSAIR 450 WATTS |17"TFT LG |2 TB SEAGATE
ultimategpu is offline
Old 17-10-2008, 02:10 AM   #8 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
I dont recommend any of this transformation packs - they modify system files. Better go for WindowBlinds + a free mac theme from www.wincustomize.com
Then any dock like ObjectDock will help too.
dheeraj_kumar is offline
Old 17-10-2008, 06:18 AM   #9 (permalink)
Sathish's Avatar
OH..I HAVE BAD LUCK FRIENDS.. GENERALLY, I TURNED OFF SYSTEM RESTORE POINT FOR SAVING DISK SPACE..
REVO UNINSTALLER DID NOT FIND ANYTHING REG FLYAKITE PROGRAMME.
CAN I GO TO REPAIR SYS FILES USING WINXPSP1 CD..??
Sathish is offline
Old 17-10-2008, 06:41 AM   #10 (permalink)
AMD & ATI FANBOY
u told that u installed sp3 .. so ------> so u have vista inspirat 2 or above version cause VI 2 has shell32.dll & run32.dll as same as xpsp2 --------> try that
Old 17-10-2008, 05:18 PM   #11 (permalink)
gkbhat.blogspot.com
While installing sp3 the system will backup all the system files in a folder.
(I don't know its name) from that folder copy shell32.dll and run32.dll then paste to
windows\system32 .
(To find the name of backup folder search with windows search for shell32.dll with option selected for searching sysetm files in your system drive .You will get 2 results one
in system32 folder and the other is the backup made by sp3)
gk2k is offline
Old 17-10-2008, 08:43 PM   #12 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
DOn't use FLYKITE, cause when I used it, my KIS 2009 started banging itz head up n down, and aftr downloading another copy and successfully installing(widout any bangs), i began regretting it cause it was causing probs, like my sound wasn't working anymore, strange isn't it!
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 17-10-2008, 08:45 PM   #13 (permalink)
TechTin.com
ravi_9793's Avatar
start -->> run -->> type sfc /scannow -->> Ok
when asked insert windows XP cd. Comple the process, should solve the problem.
Urgent help needed regarding TCS - PLZ HELP ME mrintech Chit-Chat 1 07-01-2008 10:20 PM
Urgent Help Needed! Krish_88 QnA (read only) 2 29-04-2007 12:31 AM
urgent help needed babuli_05 QnA (read only) 8 14-01-2007 11:15 PM
Urgent help needed vignesh Open Source 6 09-08-2005 08:09 AM
URGENT HELP NEEDED striker_1909 QnA (read only) 3 01-12-2004 06:12 PM
- by chris
