Old 16-10-2008, 09:46 AM   #1 (permalink)
Indidiot
Plasma_Snake's Avatar
Default Vista Help
Well I today installed Vista Ultimate 64-bit and is lookin OK, not as fast and crisp as XP but will do the job. Just want to know the following:
  1. Where's my Aero? How to turn it ON?
  2. Where's my DirectX 10? How to get it?
  3. Will using 32-bit apps on a 64-bit OS gonna cause any trouble? I'm trying to use at least the drivers 64-bit but most apps are 32-bit like Firefox,Winamp,VLC,Avast,Spybot etc. Are they going to possess or get into any trouble in this 64-bit environment?
Clear my doubts and ye shall thrive.
Plasma_Snake is offline
Old 16-10-2008, 10:00 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Vista Help
1) Update all the drivers
2) Run the system analysis again
DirectX 10 is API. Vista comes with directx 10.
you should be able to run 32 bit apps without any problem
desiibond is offline
Old 16-10-2008, 11:20 AM   #3 (permalink)
Indidiot
1) Update all the drivers -Done
2) Run the system analysis again- Done
Now I've got my Aero, its running OK but When I tried to install programs through Digit's DVD's Autorun Interface, none of them ran. I had to manually run the installers from DVD contents. In case of VLC, all I got was a Zip file which later unzipped to a folder containing just files of VLC, how to actually install it, please guide me. Is it going to be like Linux, compiling Source Code to get it up and running?
Old 16-10-2008, 11:38 AM   #4 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Lightbulb Re: Vista Help
Since you got the Zipped version of VLC, it is the non-installer version. That means it does not come with an installer and cant be installed. But the program executable is given there and you can run VLC just by clicking it.
debsuvra is offline
Old 16-10-2008, 11:50 AM   #5 (permalink)
Indidiot
Dood I know that but in XP it ran like a charm and was able to shell extend it and all the usual stuff, here it is lying in a folder like a P.O.S which it is not.
Old 16-10-2008, 03:57 PM   #6 (permalink)
evewin89's Avatar
that is why i consider XP,as the best os.
Evil Lives 4ever......
evewin89 is offline
Old 16-10-2008, 04:04 PM   #7 (permalink)
Indidiot
Read my siggy and u'll know why I had to shift to this god-awful OS!
Old 16-10-2008, 04:11 PM   #8 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^^ still dunno why!!!!!!!!
XP maharaj ki JAI!!
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 16-10-2008, 04:44 PM   #9 (permalink)
Indidiot
I had to shift because now my RAM is 4GB plus 512MB GDDR3 memory of GPU. XP showed only 3.25GB of RAM whilst now in 64-bit Vista I'm able to fully utilize mt RAM.
Old 17-10-2008, 09:52 AM   #10 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Surely 32 bit XP can't do justice with 4GB RAM while 64 bit Bit Vista can. But I wonder what you'll do with that huge amount of memory to 'fully utilize' it ?
debsuvra is offline
Old 17-10-2008, 10:03 AM   #11 (permalink)
Indidiot
OK then here's what I do on my PC:
  1. GAMEZ
  2. Visual Studio 2008
  3. SQL Server 2008
  4. Netbeans
  5. Try Blender and other Animation and Design products
  6. Game Programming
  7. Game Designing
All of the above mentioned tasks are done by me at my own accord, no one teaches or coaches me so there is lot of trial and error involved.
With my new MOBo, in XP the songs sounded awesome and the level of Bass that was earlier provided by my Sub at 4th level was now available at 2nd but in Vista everything has F'd up. I've installed the Realtek drivers, configured the Speakers internally in Vista too, set output volume to maximum but still Output is weak and even turning the bass full up on both Sub and in Winamp doesn't gives good sound. WTH is going on???
Last edited by Plasma_Snake; 17-10-2008 at 01:41 PM. Reason: Automerged Doublepost
Old 17-10-2008, 03:43 PM   #12 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Try reformat, and don't install SP1, that's like only thing I can say now!!
About me:
Old 17-10-2008, 03:46 PM   #13 (permalink)
Bond, Desi Bond!
desiibond's Avatar
  1. GAMEZ
  3. SQL Server 2008
  4. Netbeans
  6. Game Programming
  7. Game Designing
For one time, play the song in Vista Media Center app. You will see lot of difference in audio quality.
Old 17-10-2008, 04:59 PM   #14 (permalink)
Indidiot
U mean Windows Media Player 11. I did that too and when switched the speakers type to large speakers, no audio output at all!
Well i tried "Windows Media Center" too and here the problem gets worse, it tries to emulate 5.1 surround sound in basic MP3 songs which kills the bass even further, looks like for songs XP is best but I intended to use Vista for these multimedia purposes only and now this is what I get, shitty sound from my good audio setup
Last edited by Plasma_Snake; 17-10-2008 at 08:14 PM. Reason: Automerged Doublepost
Old 18-10-2008, 10:00 PM   #15 (permalink)
Indidiot
So I had to reformat my system again today and earlier too I was using Google's Desktop search on my 64-bit Vista Ultimate and now today when I tried to do so again I got the error that "Google Desktop is not currently compatible with your operating
system. It requires a 32-bit version of Windows Vista, Windows XP
or Windows 2000 Service Pack 3 or above." I tries to run it in compatibility mode for XP SP2 but still of no use. Help me guys!
Old 18-10-2008, 10:12 PM   #16 (permalink)
The Devil's Advocate
iMav's Avatar
1. Vista's sound output is much (read again, much) better than XP. What audio card & version of drivers are you using?
2. Google Desktop is only for 32bit XP/Vista, so you cannot use it. A fact accepted by Google and they have said that it is something that they might *consider*.
http://beingmanan.com
iMav is offline
Old 18-10-2008, 11:20 PM   #17 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
@ Plasma Snake, I think you are not using the proper 64 bit WHQL certified drivers for your sound card in Windows Vista Ultimate 64 bit. May be that is the sole reason for bad audio.
debsuvra is offline
Old 19-10-2008, 12:17 AM   #18 (permalink)
Indidiot
Angry Re: Vista Help
This is my RealTek driver info:
Driver Version- 6.0.1.5628
DirectX version- 10.0
Audio Controller- HD Audio
Audio Codec- ALC1200
Sound from every place, i.e. in Realtek setup, Window's configuration, everywhere has been configured to the max but still the sound I'm getting is not upto the level, which I was getting in XP. Bass has been just snuffed out, highs and mids are clear but without bass they r just waste. Moreover as I said b4, audio level too has dropped, the intesity of sound available at low levels is now accessed at comparably high level.
The sound card is onboard solution available on my ASUS P5QC motherboard and it is very good considering the fact that S/PDIF connectors are also available. Speakers are Creative T6060! The drivers I'm using r the ones that came in the mobo's DVD. how to update them?
Old 19-10-2008, 12:31 AM   #19 (permalink)
iMav's Avatar
Try downloading the drivers here:
http://support.asus.com/download/dow...Language=en-us
Alternately to search for updates:
Device Manager -> Sound, video... -> Properties -> Update driver.
iMav is offline
Old 19-10-2008, 01:15 AM   #20 (permalink)
Indidiot
I did the latter and there were no updates available. Just checked the link too, provided above, Audio drivers are up to date and WHQL certified. Problem that I've perceived is that Vista is trying to make stereo mp3 songs into multi channel ones, spreading sound over all channels thus giving better highs and mids but killing Bass in the process.
Old 19-10-2008, 01:36 AM   #21 (permalink)
iMav's Avatar
Try 2 things:
1. Control panel -> Sound -> Playback -> Speakers -> Enhancements -> Uncheck "Disable all sound effects".
If that does not work...
2. Under device manager roll back to a Vista driver as in don't install Realtek drivers use Vista's drivers.
If nothing happens, contact Asus.
iMav is offline
Old 19-10-2008, 07:47 PM   #22 (permalink)
Cool Buddy's Avatar
wonder why, on my computer, ive not been able to get the sound quality offered by vista in XP. MP3s sound awesome in vista on my creative 2.1
mobo MSI K9NGM
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 19-10-2008, 07:48 PM   #23 (permalink)
iMav's Avatar
There's some config issues on his machine. It's not Vista but some settings not proper.
iMav is offline
Old 19-10-2008, 10:21 PM   #24 (permalink)
Indidiot
In my next post I'll give u screenies of my config and then u can tell me if its all right or anything wrong
Old 20-10-2008, 10:00 AM   #25 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^What imav said is true. Am getting superb audio quality in Vista's media center. YOu may have to setup speakers again in VMC.
1) Go got Vista Media center -> Tasks -> Settings
2) Go to Windows Media Center Setup
3) Set Up Your Speakers
4) Click on Next
5) Select "2 speakers", click on Next
6) Test and click on next
7) Click on Finish. Now try to play audio in media center.
Also, go to WMP11 and disable SRS and Bass, set the equalizer to one tha suites your need better. Then play music over Vista Media Center.
PS: Vista Media Center uses WMP11 to play audio and video.
Old 20-10-2008, 11:08 AM   #26 (permalink)
Indidiot
Below are the imageshack links to my screenshot uploads of my Audio Configuration,please check them out. My preferred audio player is Winamp and for Video its VLC.
Wud have loved to give the screenies itself here but forum doesn't allows more than 15 so here are the links to the images.
http://img407.imageshack.us/my.php?i...faudio3do8.jpg
http://img407.imageshack.us/my.php?i...ealtek7ch0.jpg
http://img296.imageshack.us/my.php?i...ealtek2me2.jpg
http://img296.imageshack.us/my.php?image=config1ge0.jpg
http://img206.imageshack.us/my.php?i...olevelspd0.jpg
http://img296.imageshack.us/my.php?i...oconfigkr8.jpg
http://img362.imageshack.us/my.php?i...gfinaleuz1.jpg
http://img206.imageshack.us/my.php?i...ealtek1rv3.jpg
http://img517.imageshack.us/my.php?i...ealtek6ng2.jpg
http://img521.imageshack.us/my.php?i...faudio2ek6.jpg
http://img529.imageshack.us/my.php?i...efaudione3.jpg
http://img529.imageshack.us/my.php?i...ealtek5ch4.jpg
http://img206.imageshack.us/my.php?image=config3tp8.jpg
http://img206.imageshack.us/my.php?i...ealtek4rq6.jpg
http://img206.imageshack.us/my.php?i...ealtek9ss8.jpg
http://img49.imageshack.us/my.php?image=realtek8mb5.jpg
http://img362.imageshack.us/my.php?i...ealtek3lg9.jpg
http://img362.imageshack.us/my.php?image=config2qx7.jpg
So i tinkered with the settings a lil bit more and did these 2 things:
  1. Swapped Center channel and Subwoofer inputs from Realtek Audio manager.
  2. Disabled the Bass Management.
The bass has considerably improved but the intensity problem persists. Guess would have to live with it till Windows 7 comes out or migrate completely to Linux.
Last edited by Plasma_Snake; 20-10-2008 at 11:27 AM. Reason: Automerged Doublepost
Old 20-10-2008, 12:45 PM   #27 (permalink)
Fullbring
Zangetsu's Avatar
Hey..plasma..there is a thread on the same topic..on how 2 utilize RAM in 32-Bit XP
even if u have more than 3.5GB of RAM....so,no problem @ all
Zangetsu is offline
Old 21-10-2008, 08:50 AM   #28 (permalink)
Asus onboard sound does have a problem with x64 vista, specially if you have 4.1 or 5.1 speakers. If you select 2.1 output then it sounds better.
Sound in Xp is better & thats one of the reason I am still with XP (dual boot)
ranjan2001 is offline
Old 23-10-2008, 08:14 AM   #29 (permalink)
Indidiot
Few days back I extended a partition on my 400GB HDD using Vista's in-built partitioning tool. It made the 400GB HDD into a Dynamic disk. Can I revert it back to its non-dynamic nature with some other partitioning tool? Will there be any loss of data in the process?
Old 24-10-2008, 04:08 PM   #30 (permalink)
Indidiot
Koi jawaab to do!
VISTA THEME: Vista Blue Refresh Theme for Vista Basic Users Vishal Gupta Random News 13 13-04-2008 01:28 PM
How to change the boot menu text in Vista, if you are dual-booting Vista & Vista. anandk Tutorials 6 05-12-2007 02:54 PM
VISTA THEME: Vista Blue RTM with Aero Buttons for Vista BASIC Users Vishal Gupta Random News 5 05-09-2007 04:29 PM
VISTA THEME: Vista Black for Vista Basic with Aero Buttons Vishal Gupta Random News 7 26-08-2007 06:13 PM
VISTA THEME: Vista Blue by Mr. Vista // Vishal Gupta Chirag Random News 14 07-08-2007 02:44 AM
- by chris
