Old 14-10-2008, 02:37 PM   #1 (permalink)
Default Help with dual boot options
i got the same windows installed on two drives on C: and Ddrive
how do i remove Ddrive installation completely?? ( even from boot screen option)
ank_panwar is offline
Old 14-10-2008, 02:48 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Help with dual boot options
Boot into Windows installed in C: drive and then format D: drive by right-click on its icon and select Format.
Now you can remove its entry from "Boot.ini" file using "System Properties" or "msconfig" or by directly editing the file in Notepad.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 14-10-2008, 03:47 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
Hahaha..its very simple
Zangetsu is offline
Old 14-10-2008, 06:09 PM   #4 (permalink)
lol..............tht was easy
thnks
Old 14-10-2008, 06:12 PM   #5 (permalink)
TheSaint
NucleusKore's Avatar
Very simple
Sorry Vishal, but I think if the OP knew all this he would not have asked in the first place.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 14-10-2008, 07:05 PM   #6 (permalink)
AMD & ATI FANBOY
ultimategpu's Avatar
1)if u have want to uninstall the another OS ----- format the other one using same XP CD bootable there will be formatting option
2)then u wana delete another OS boot screen option then -> right click on the my computer -> go to [advanced] option then ->select startup and recovery -> then see startup option edit the two lines the OS shows delete another OS boot screen line using notepad and save ------------->COMPLETE
ultimategpu is offline
Dual boot Linux - boot failure after XP Encryption patkim Software Q&A 1 23-03-2008 11:00 AM
How to boot in xp in safe mode (Vista + XP Dual Boot) CadCrazy Software Q&A 6 14-08-2007 11:43 AM
Boot options iMav Software Q&A 7 25-03-2007 12:54 PM
AMD 939 pin dual core upgrade options. abhijit_reddevil Hardware Q&A 1 09-12-2006 10:20 AM
two xp boot options??? HELP!!!! vengeanceofdeath Software Q&A 5 07-08-2004 12:06 PM
- by chris
