Old 09-10-2008, 01:24 PM   #1 (permalink)
Excessive happiness
furious_gamer's Avatar
Default Problem with DVD-RW
I have an Lenovo Y500 lappy and yesterday, when i start writing in my DVD it starts the progress, it goes upto 2% and then it shows an error, "Power Calibration Error"...
What is it?....
I didn't even write CD's? Whats wrong with my DVD Writer....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is offline
Old 09-10-2008, 01:40 PM   #2 (permalink)
The Black Waltz
Default Re: Problem with DVD-RW
Check this out- http://www.megaleecher.net/Fix_Power_Calibration_Error
#krow @ irc.freenode.net
Cool Joe is offline
Old 09-10-2008, 01:53 PM   #3 (permalink)
Excessive happiness
Originally Posted by beta testing View Post
Dude, that link doesnt open.... Will u plz explain that here...
PS Request
Old 09-10-2008, 05:04 PM   #4 (permalink)
The Black Waltz
There could be several possible reasons and solutions for this error, basically what is happening is for some reason the CD/DVD burning software is unable to determine the Optimum Power Calibration rate (a small pre-burn test to determine optimal laser power for writing), resulting a disk burn failure. There is no easy way to pinpoint the exact reason, so try all the possible fixes from top to bottom (easy to hard) and see what works:
Try using different brands of quality blank media, most common reason for such error's is cheap blank media.
Try burning at lower speeds (Highly effective).
Disable IMAPI Service (Work's in most cases):
1. Launch Control Panel -> Administrative Tools -> Services .
2. Browse for "IMAPI CD-Burning COM Service", Right-click on it and select properties.
3. Change Startup Type to Disabled.
4. Click Apply and Reboot.
Try updating or changing your CD\DVD burning software to the latest version.
Try upgrading your writer's firmware.
If all the above fails the problem is definitely related to hardware and not software, Go ahead and get your burner laser lens cleaned by a professional.
If all the above fails the drive's laser might have died and you need to get it replaced.
Cool Joe is offline
Old 10-10-2008, 12:22 PM   #5 (permalink)
Excessive happiness
I'll try it...
Thanks for that beta_testing...
PS Request
Old 10-10-2008, 12:51 PM   #6 (permalink)
The Black Waltz
You gotta thank the guy from the site. If you can't visit it, then at least a silent prayer of thanks for him.
Cool Joe is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by chris
