Old 09-10-2008, 06:17 AM   #1 (permalink)
Default Pls help me to access my hard drives
Yesterday i downloaded software called Easydrivelock 4.1 trail version ..the software was easy to lock the hard drives so i locked 2 very importand hard drives excluding c: in which window is installed ... now when i unlock it it accepts my password but i m not able to open my 2 drives which are D and E. when i open easydrive lock it asks me to purchase the software which is about 30 dollars i really dont want that software and juz want to open the lock .. please kindly tell me ... this software also warns not to reinstall window before unlocking all drives .. i m afraid to do so even what should i do plzz suggest
bratsameer is offline
Old 09-10-2008, 08:30 AM   #2 (permalink)
paroh's Avatar
Default Re: Pls help me to access my hard drives
First try this
Easy Drive Lock 4.1
I learned that any locked partitions can be accessed, if you enter the full path of an item (file or folder) into Windows Explorer. So much for protection. A locked partition can be accessed either locally or by using a remote machine this way.
For backup reason
Copy all contents from that lock partition to some other partition and uninstall Easy Drive Lock 4.1. and if u could access the locked partition directly its good other wise format that locked partition.
paroh is offline
Old 10-10-2008, 12:47 PM   #3 (permalink)
Blogger
hariharakumar's Avatar
Many of the softwares that lock drives uses Registry values to lock. Since your drives are locked, and you cant open them, i ask you to check the Registry and change the value. But REMEMBER CHANGING VALUES IN REGISTRY WITHOUT KNOWING CAN LEAD TO MALFUNCTION OF WINDOWS, SO BE CAREFUL, BACKUP YOUR REGISTRY BEFORE CHANGING ANY VALUE, YOU CAN USE BACKUP TO RESTORE YOUR SYSTEM SETTINGS IF ANYTHING HAPPENS.
This link tells you how to backup your registry
http://support.microsoft.com/kb/322756
This link tells you how to Hide and lock any drive(s) using regedit
http://www.computerforumz.com/showthread.php?t=914
Visit my blog at http://geekspage.tk/
Check my blog for updates on Blogging, Social Media, Software.
follow me on Twitter: http://www.twitter.com/hariharakumar
hariharakumar is offline
Old 10-10-2008, 04:11 PM   #4 (permalink)
mad_max's Avatar
what da hell kind of a trial is that:S thats (put your fav swear word here) blackmail
mad_max is offline
Old 27-11-2008, 10:15 AM   #5 (permalink)
Red face Re: Pls help me to access my hard drives
Dont Buy this software it is useless. If you lock the drive you will lost all datas.
If you have problem with Lock You can take backup the datas in windows utility.
juli_naz is offline
Old 19-04-2009, 09:56 AM   #6 (permalink)
firstly after locking the drive data cannot be copied.also there is no registry entry that can be deleted to restore the drive
i tried using a fake key to make easy drive lock fullversion,IT STILL DOES NT WORK
Posted again:
Originally Posted by paroh View Post
First try this
Easy Drive Lock 4.1
For backup reason
Last edited by rajeevisgupta@yahoo.com; 19-04-2009 at 09:57 AM. Reason: Automerged Doublepost
rajeevisgupta@yahoo.com is offline
Old 20-04-2009, 11:42 PM   #7 (permalink)
mad_max's Avatar
Posted again:
you brought up a half year old thread to say this?
mad_max is offline
Old 21-04-2009, 02:01 PM   #8 (permalink)
well m not sure its gonna work.
as i dont know too much abt compu
but give this a try too.
try to make a back up by connecting ur hard disk to another pc
and then make a full partition of hard disk(or atleast locked drives)
rohitbhu06 is offline
Old 21-04-2009, 02:11 PM   #9 (permalink)
use linux live cd and access drives, take backup, FORMAT !!!
Faun is offline
How to access all drives/dir. frm recovery console??? Rajneesh QnA (read only) 1 16-09-2008 02:48 PM
Can't access USB Hard Disk over network, can access directly, any ideas why ? din Networking 1 09-12-2007 03:06 PM
How to access all Drives & Folders In XP Recovery Console? Vishal Gupta Software Q&A 8 17-09-2005 08:45 PM
How to access Windows Fat or NTFS Drives in Red Hat 9 Linux? thinkAI Open Source 1 14-07-2005 10:18 PM
- by chris
