Old 07-10-2008, 08:51 PM   #1 (permalink)
Default Problem in Transcend USB Drive of JF V10
Hi Friends,
i had a Transcend USB Drive of JF V10..
the problem it is not detecting that from my system and nt showing the Icon in TaskBar..
i use to copy the files into that and vice versa and working fine in past..
today i had a problem that it is not detecting ..
i tried in other system it is showing the icon in Task Bar But when i click on the Icon
it throws an error is
The error is
the USB Device Drivers is not installed
The drivers for this device are not installed.
To reinstall the drivers for this device, click Reinstall Driver.
canu get out of this
Thanks in advance
Seenujanu
januseenu is offline
Old 07-10-2008, 09:46 PM   #2 (permalink)
The Black Waltz
Default Re: Problem in Transcend USB Drive of JF V10
As the message says, you'll need to install the drivers for your drive. The drivers will have been bundled with your drive. There'll also be instructions on how to go about it. Check it out.
#krow @ irc.freenode.net
Cool Joe is offline
Old 07-10-2008, 09:47 PM   #3 (permalink)
swatkat's Avatar
Check out this page... It might help you!!
http://www.troublefixers.com/pen-dri...ter-unlock-it/
http://swatrant.blogspot.com/
swatkat is offline
Problem with Transcend 8 GB Pen Drive mrbgupta Hardware Q&A 9 22-02-2008 04:47 PM
Transcend or Kingston Pen Drive? Gigacore QnA (read only) 10 14-10-2007 11:19 AM
mFormat for Transcend 2GB usb drive almighty Software Q&A 2 03-10-2007 01:23 PM
Transcend T sonic 610 as pen drive? suyash_123 QnA (read only) 18 08-01-2007 09:38 PM
- by chris
