Old 06-10-2008, 09:58 PM   #1 (permalink)
Default Problem with Kaspersky Antivirus 2009
I have a broadband connection. And it worked fine when I had only ESET Smart Security Antivirus. But recently I decided to install one extra Antivirus - Kaspersky Antivirus 2009. It got installed quite fine on my system. But the problem started when I tried to connect to the internet. It shows that broadband is connected, but whenever I tried to acces any website it can not open it. Then I decided to uninstall Kaspersky Antivirus. And after uninstalling I tried to access any website and it worked as it previously worked, it was all ok.
So what is the problem with Kaspersky Antivirus?
I want it installed in my system. Plz tell me how to get rid of this problem....
Plz help.......
Adam Cruge1 is offline
Old 06-10-2008, 10:37 PM   #2 (permalink)
swatkat's Avatar
Default Re: Problem with Kaspersky Antivirus 2009
Probably you can check out their user guide for firewall configuration...
http://www.kaspersky.com/downloads/p...r_guide_en.pdf
By the way, it's not recommended to have multiple antivirus/firewall in a system...
http://swatrant.blogspot.com/
swatkat is offline
Old 06-10-2008, 10:52 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Exactly..pricking off from there...multiple Firewalls/AVs?/ISs conflict and cause problems and sys crashes blah blah...so keep one..Kaspersky alone is gud enough
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 07-10-2008, 11:44 AM   #4 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
yup agree to it, btw (to the original poster) plz, if u wanna install any other AV/firewall etc uninstall the previous ones and yes, ues a registry entry remover like XP Tools or CC cleaner so tat as soon as the s/w is uninstalled, its entries are also COMPLETELY removed from the registry..
sumtimes, u can manually DELETE the left over folders of such s/w if they are being left back after a reg uninstall too..
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 07-10-2008, 11:59 AM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
U want complete removal of registries...go for Revo uninstall..nothing left I gurantee(no ads here okay)
About me:
Old 09-10-2008, 10:46 PM   #6 (permalink)
I checked their user manual for firewall configuration...but I did the the same setting as described there...Yet the problem is not solved....
Plz help...
Symantec introduces 2009 range of products including NORTON ANTIVIRUS 2009 apoorva84 Technology News 34 19-09-2008 11:01 PM
Kaspersky 2009 killed my DVD drive !! naveen_reloaded QnA (read only) 7 11-08-2008 12:02 AM
Kaspersky Internet Security 2009 Krazy Bluez Internet & WWW 12 23-07-2008 01:31 PM
FREE 1 Year Kaspersky Internet Security 2009 Genuine License cool_techie_tvm Random News 55 13-07-2008 10:50 AM
[Query]Kaspersky 2009 Licence Charan QnA (read only) 3 09-06-2008 09:16 PM
- by chris
