Old 06-10-2008, 10:29 AM   #1 (permalink)
himadri_sm's Avatar
Default Help!system wont boot!:-(
On booting,after the POST screen,my friends laptop shows a blue screen & restarts.the error code is 0x0000007b. Windows doesnot detect the hdd.if i use a linux live cd(puppy linux),the drives do not appear.it cannot be formatted as setup says-no hdd is installed.his laptop make is hp dv9222tx.how do i solve this problem?
himadri_sm is online now
Old 06-10-2008, 10:45 AM   #2 (permalink)
Krazy_About_Technology's Avatar
Default Re: Help!system wont boot!:-(
This message is related to the hard disk controller or the hdd itself. Are you using a SATA hdd or a Parallel ATA disk? If using SATA, try disabling SATA native mode from BIOS. In some BIOS this option will be given as Enable Legacy mode.
Was he able to boot before? When did it started happening, just after purchase or after using for some time?
Try that and report back. I hope it will solve your problem.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 06-10-2008, 11:28 AM   #3 (permalink)
himadri_sm's Avatar
Red face Re: Help!system wont boot!:-(
^thanx a lot...disabling SATA native support worked..but why did it happen? what does SATA native support mean? what is its use?
P4 system wont boot hellgate Hardware Q&A 8 30-03-2008 10:16 PM
xp wont boot amey_dude Software Q&A 7 10-02-2008 12:34 PM
New System Wont Boot adit_sen Hardware Q&A 6 01-02-2008 11:08 PM
help: PC wont boot :(( Jags Software Q&A 3 29-04-2007 11:12 PM
System wont boot.......fdisk wont work.......xp wont install irradiated_chicken Software Q&A 10 10-06-2005 10:50 AM
- by chris
