Old 05-10-2008, 06:50 PM   #1 (permalink)
Default help! virus
hi,
my system slow down every 20 - 30 min after booting .. i found a problem in temp file named C:\LOGFILE.ETL . file size increasing in every second . after 20-30 min harddisk full notification come from tray . unable to delete ....
help me
screeshots :
http://img530.imageshack.us/img530/8...t051836xy3.gif
http://img88.imageshack.us/img88/626...t051836yv7.gif
http://img379.imageshack.us/img379/4...t051837oj3.gif
http://img258.imageshack.us/img258/3...t051844bx1.gif
dsuresh is offline
Old 05-10-2008, 07:22 PM   #2 (permalink)
swatkat's Avatar
Default Re: help! virus
Do you have/used any utility called Tracelog.exe? It is a part of Windows ResKit.
http://swatrant.blogspot.com/
swatkat is offline
Old 06-10-2008, 01:07 AM   #3 (permalink)
No , i am not a power user ...
dsuresh is offline
Old 06-10-2008, 11:25 AM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
If prob persists...well..sorry but full system format if tht's feasible for u
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 06-10-2008, 10:50 PM   #5 (permalink)
swatkat's Avatar
Hi,
Can you tell me what are the values present in the following Registry Key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\WMI\GlobalLogger
You need to use Registry Editor (type regedit.exe in Run dialog box) to view the above mentioned key. A screenshot would help!
By the way, are you using or have you used a program called BootVis?
swatkat is offline
Old 06-10-2008, 11:58 PM   #6 (permalink)
http://img148.imageshack.us/img148/7...t062356kb4.gif
dsuresh is offline
Old 07-10-2008, 01:06 AM   #7 (permalink)
swatkat's Avatar
Thanks. Can you change the Start value in that Registry Key to 0? To do this, double-click on the value "Start" and change the value from 1 to 0. Reboot PC and see if the logfile.etl still continues to grow...
If you don't have Registry editing permissions in your user account, then you need to do it using an user account with Admin privileges...
swatkat is offline
Old 07-10-2008, 02:34 AM   #8 (permalink)
thanks swat cat .............. problem solved .......... thanks again
dsuresh is offline
Old 07-10-2008, 09:37 PM   #9 (permalink)
swatkat's Avatar
Cool I wonder how WMI system/kernel logger was turned-on in your system!!
swatkat is offline
Old 07-10-2008, 09:46 PM   #10 (permalink)
afonofa's Avatar
Talking Re: help! virus
I really hope you never get to be in control of India's nukes!
afonofa is offline
about a virus which attacked me,need guidence and giving info abt this virus-read mobileman Software Q&A 2 16-11-2007 12:43 PM
Virus trouble (VERY weird stalker virus) mightyboosh Software Q&A 9 22-08-2007 11:34 PM
Virus problem, need online virus checking details-pls hava a read here. mobileman Software Q&A 2 14-04-2007 10:58 AM
mcafee virus scan 8.0 - problem updating virus definations infra_red_dude Software Q&A 3 26-06-2005 11:43 AM
VIRUS...RANDEX ZEN.......VIRUS MLORE HELP..??URGENT Writankar panja Software Q&A 9 19-09-2004 05:26 PM
- by chris
