Old 02-10-2008, 07:33 PM   #1 (permalink)
The Black Waltz
Default Strange problem with MS Office 2007
I've a strange problem with MS Ofice 2007. I can't type anything in MS Word, and all options are greyed out. This happens not only in Word, but also in other MS Office programs. Plz help....
#krow @ irc.freenode.net
Cool Joe is offline
Old 02-10-2008, 07:35 PM   #2 (permalink)
Debian Gnu/Linux User
Sathish's Avatar
Default Re: Strange problem with MS Office 2007
do you have genuine copy..?
i have also MS office 2007 without no problem..
pl check the activation details..
Living for Learning & Learning for Living
Sathish is offline
Old 02-10-2008, 08:01 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Not that, genuine can't be a problem, cause itz only been a month since I got the original copy(before tht, using the ** version for 3 months)
Were u using trial version wich has expired now?
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 02-10-2008, 08:10 PM   #4 (permalink)
Sathish's Avatar
yes i agree.
but some times pirated copy can be disabled the applications while the internet connection is up at the time of installations.
Sathish is offline
Old 03-10-2008, 01:01 PM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Well, strange...letz see. what he replies..cause it din happen for me(using ahem copy)
About me:
Old 03-10-2008, 04:50 PM   #6 (permalink)
The Black Waltz
I'm using the 60 day trial which came with the Digit CD. And it hasn't been 60 days I think. If it had, then it would've notified me about it.
Cool Joe is offline
Old 03-10-2008, 04:56 PM   #7 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Man it only happens when your trail is over
Same happened with but later got a original copy from a Friend...
I spit Rainbows.
skippednote is offline
Old 03-10-2008, 08:38 PM   #8 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Well, sadly u dun live nerby( i wud hav given my *ahem* copy...)
About me:
Old 03-10-2008, 08:49 PM   #9 (permalink)
Hmm, I suggest u uninstall it first and then reinstall it back again and see if you still got the same problem..
fatskin08 is offline
Old 03-10-2008, 09:30 PM   #10 (permalink)
afonofa's Avatar
Talking Re: Strange problem with MS Office 2007
LoL *ahem* copy
You can always *ahem*rrent your copy to the OP.
afonofa is offline
Old 03-10-2008, 10:34 PM   #11 (permalink)
The Black Waltz
Of course, I know that reinstalling it will take care of the problem, just wanted to know if there was another way out. And I don't need the *ahem* copy, there's just a simple hack to make the trial version function like the full version.
Cool Joe is offline
Old 04-10-2008, 12:26 PM   #12 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Ohh..was unaware of the hack...but my ahem has 2007+(dunno mabe xtra features)....
Well.....I waz nvr ever successful in finding cracks and keys to any program, genuineness kept me to it I guess
About me:
Old 04-10-2008, 01:25 PM   #13 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
wow, lots of ahem ahem... benedril anyone?
dheeraj_kumar is offline
Old 04-10-2008, 02:58 PM   #14 (permalink)
Fullbring
Zangetsu's Avatar
Xpired....
I dont like MS Office 07 bcoz of its awkward layout....
I still dont know where is the option for "about box" in it....how silly
Zangetsu is offline
Old 04-10-2008, 03:55 PM   #15 (permalink)
Sathish's Avatar
Ho..shut..
pl go to word option>resources> my friend.
nothing has to be compared msoffice 2007..
Sathish is offline
Old 04-10-2008, 04:20 PM   #16 (permalink)
The Black Waltz
So no other option but reinstall?
Cool Joe is offline
Old 07-10-2008, 12:19 PM   #17 (permalink)
The Black Waltz
So I tried to uninstall.... I can't even uninstall it because when I try to, I get an error saying that some file is missing or corrupt.
I think Office isn't working due to this corrupt file. It doesn't even mention the name of the file so I can't fix it....
Cool Joe is offline
Old 07-10-2008, 09:49 PM   #18 (permalink)
swatkat's Avatar
This page might help you to uninstall Office 2007 if you are not able to do it from "Add/Remove Programs":
http://support.microsoft.com/kb/928218
http://swatrant.blogspot.com/
swatkat is offline
Old 07-10-2008, 10:18 PM   #19 (permalink)
The Black Waltz
Thanks for the link Swatkat. I did almost all the steps. I just have to remove the registry keys now. I guess I'll do it later (it's a tedious job).
Thanks all
Cool Joe is offline
Old 07-10-2008, 10:22 PM   #20 (permalink)
swatkat's Avatar
Welcome! Hopefully that link will help you!
swatkat is offline
Old 07-10-2008, 10:55 PM   #21 (permalink)
Section Moderator
gopi_vbboy's Avatar
use openoffice or msoffice2003..............the 07 ver sucks
gopi_vbboy is offline
Old 07-10-2008, 11:32 PM   #22 (permalink)
Ballack Junior
tuxybuzz's Avatar
exactly..openoffice is awesome..for word processing and all..but then impress cant match powerpoint..if its word processing openoffice..or even ABi Word..both rock..
tuxybuzz is offline
Old 08-10-2008, 07:11 AM   #23 (permalink)
The Black Waltz
Yeah that's true. Write and Calc are decent programs but nothing can match Powerpoint.
Cool Joe is offline
Old 08-10-2008, 11:34 AM   #24 (permalink)
Amir.php's Avatar
Arrow Re: Strange problem with MS Office 2007
In the last i want to tell you that Microsoft provides their office 2007 trial for only 60 clicks(Means after opening your office 60 time, your trial copy will be expire).
Keep in mind 60 days means not 2 month, but instead 60 clicks only.
Amir.php is offline
Old 08-10-2008, 12:04 PM   #25 (permalink)
Fullbring
Zangetsu's Avatar
Ya, this is principle is followed by some other softwares also...such tweakXP
But which is better 60days or 60clicks depends on usage
Zangetsu is offline
Old 09-10-2008, 05:12 PM   #26 (permalink)
The Black Waltz
Oh..... WTF....
Cool Joe is offline
Office 2007 and Vista problem...Urgent### Abhishek Dwivedi Software Q&A 4 09-02-2008 01:37 PM
Customizing office 2007 Ribbon to look like office 2003 spidyweb Software Q&A 2 22-01-2008 05:15 PM
Office suites...open source alternative to office 2007 bikdel Open Source 21 23-11-2007 03:01 PM
Microsoft Office 2007 Problem........ BBThumbHealer Software Q&A 6 24-02-2007 10:21 PM
Office 2007 installation problem deepak.krishnan Software Q&A 4 15-02-2007 08:19 PM
- by chris
