Old 02-10-2008, 05:22 PM   #1 (permalink)
D PrankMaster
prankie's Avatar
Default problem with ubuntu!!
I'm totally new to linux. i just installed ubuntu 8.04LTS, here is the problem i m facing,,
My fgx card is Nvidia 6200, using proprietary driver, the resolution is not going above 800*600 and refresh rate above 60Hz. then i modified stats of my monitor under etc/x11/xorg.conf (No joy!!) then i installed drivers by ENVY.. now the resolution is not going above 640*480!!! what to do..?? I'm a newbie... so plz explain briefly...
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is offline
Old 02-10-2008, 05:29 PM   #2 (permalink)
God of Mistakes...
Garbage's Avatar
Default Re: problem with ubuntu!!
Go to terminal (Applications -> Accessories -> Terminal ) and type
sudo apt-get install nvidia-glx-new nvidia-settings
it will download n install nVidia drivers. Restart computer after that...
Now again go to Terminal n type
sudo nvidia-settings
It will bring nvidia settings control panel. Here you can make changes. N remember to write to xorg.conf option there.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 02-10-2008, 05:51 PM   #3 (permalink)
D PrankMaster
prankie's Avatar
@Garbage
Done as u said
but when nvidia xserver settings window opens following error comes
You do not appear to be using the NVIDIA X driver. Please edit your X configuration file (just run `nvidia-xconfig` as root), and restart the X server.
when i try to write nvidia-xconfig in terminal window i get the error
ERROR: Unable to write to directory '/etc/X11'.
what next??
prankie is offline
Old 02-10-2008, 05:56 PM   #4 (permalink)
God of Mistakes...
Garbage's Avatar
now try... (in terminal.. ofc)
sudo nvidia-xconfig
Now, logout n login OR restart.
Then try to do sudo nvidia-setting again.
Garbage is offline
Old 02-10-2008, 06:19 PM   #5 (permalink)
D PrankMaster
prankie's Avatar
Did that.. restarted the system.. but still getting the same error.
one more thing.. under System>administration>hardware drivers
the status of gfx card is in use but under Enable there is no tick...
prankie is offline
Old 02-10-2008, 06:21 PM   #6 (permalink)
God of Mistakes...
Garbage's Avatar
Go to Application -> Add/Remove
Then make there "All Available Applications" then try ....
Garbage is offline
Old 02-10-2008, 06:30 PM   #7 (permalink)
D PrankMaster
prankie's Avatar
i restarted the system again and now i'm getting better resolution (1024*768 @75hz).. but login screen size has become 4 times!! and i can only see only a quarter of it...
OS prompted to restart.. i did that.. i was again invited with config menu.. i chose nvidia 6series driver and daewoo 710b monitor..but now the resolution is again 800*600 (max)!!!
prankie is offline
Old 02-10-2008, 06:52 PM   #8 (permalink)
God of Mistakes...
Garbage's Avatar
Check my xorg.conf from http://www.garbage.pastebin.com/m313962d2
Garbage is offline
Old 02-10-2008, 10:51 PM   #9 (permalink)
TheSaint
NucleusKore's Avatar
I think you have messed up your xorg.conf with the earlier manual edit. I'd recommend a fresh install, followed by the driver install through
System->Administration->Synaptic
Search and mark
nvidia-glx-new
nvidia-settings
Click apply.
System->administration->hardware drivers
and check the checkbox
Reboot
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 03-10-2008, 11:59 PM   #10 (permalink)
D PrankMaster
prankie's Avatar
problem solved...
removed all the drivers then reinstalled Nvidia driver by ENVY...
prankie is offline
Problem with Ubuntu! shobankr Open Source 15 17-04-2008 09:56 AM
Ubuntu Problem adi007 Open Source 46 18-11-2007 10:20 PM
problem in ubuntu 7.04 for PC hrushij Open Source 5 19-06-2007 08:55 AM
Ubuntu + AMD problem shivkumar Open Source 3 12-11-2006 05:58 PM
problem with ubuntu shivi4 Open Source 4 09-05-2006 11:13 AM
- by chris
