Old 01-10-2008, 11:28 AM   #1 (permalink)
RiGhT HeRe RiGhT nOw
ashishnehete's Avatar
Default Virus issue
Guys there is a file Adobereader9.0 in my pen drrve and hdd which i am not able to delete
it is a virus i think but it is not detected by avast wat do yaar maira proj ka kafi data hai tat i dont want to delete
ashishnehete is offline
Old 01-10-2008, 01:11 PM   #2 (permalink)
paroh's Avatar
Default Re: Virus issue
Tell the size of the file?
and try to use unlocker if the file is used by some process u can kill that process and can delete the file
unlocker info
http://ccollomb.free.fr/unlocker/#download
unlocker download
http://ccollomb.free.fr/unlocker/unlocker1.8.7.exe
paroh is offline
Old 01-10-2008, 09:53 PM   #3 (permalink)
afonofa's Avatar
Can't you quarantine the file with Avast in normal/safe mode?
afonofa is offline
Old 01-10-2008, 10:22 PM   #4 (permalink)
The Black Waltz
Update your virus definitions and scan in safe mode without networking. Also install Spyware Doctor or Spybot Search & Destroy with latest definitions. These should get rid of dumb malware like that one...
#krow @ irc.freenode.net
Cool Joe is offline
Old 02-10-2008, 12:55 PM   #5 (permalink)
Blogger
hariharakumar's Avatar
Never use any freeware versions of Antivirus, they dont detect any virus most of the times. Get some corporate version of antivirus from your friend and install. I recommend you to use corporate versions of MCAfee and Symantec Antivirus.
Harihara Kumar
http://awesome-tech.blogspot.com/
Check my blog for updates on Blogging, Social Media, Software.
follow me on Twitter: http://www.twitter.com/hariharakumar
hariharakumar is offline
Old 02-10-2008, 02:52 PM   #6 (permalink)
Wise Old Mouse
mrintech's Avatar
Who said this
Dude freewares do a decent job. Better scan your PC with a-Squared and Spyware Terminator: http://tech-baby.co.cc/best-combinat...for-home-users
Regrading Antivirus opt AVG or Avira Antivirus
- MrinTech: http://mrintech.com/
mrintech is offline
Old 02-10-2008, 02:57 PM   #7 (permalink)
The Black Waltz
Dude what are you talking about? AVG, Avast and Avira are damn good free AVs and I would rate them higher than Symantec anyday.
Cool Joe is offline
Old 02-10-2008, 08:02 PM   #8 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Well, copy all the files of the USB, except the Reader 9.0 file.
Then try formatting.
If not, then Safe Mode and format it
http://pleaseguide.me/
comp@ddict is offline
virus issue ritish Software Q&A 3 04-03-2008 11:44 AM
about a virus which attacked me,need guidence and giving info abt this virus-read mobileman Software Q&A 2 16-11-2007 12:43 PM
Virus problem, need online virus checking details-pls hava a read here. mobileman Software Q&A 2 14-04-2007 10:58 AM
mcafee virus scan 8.0 - problem updating virus definations infra_red_dude Software Q&A 3 26-06-2005 11:43 AM
VIRUS...RANDEX ZEN.......VIRUS MLORE HELP..??URGENT Writankar panja Software Q&A 9 19-09-2004 05:26 PM
