Old 30-09-2008, 05:33 PM   #1 (permalink)
Wise Old Mouse
mrintech's Avatar
Exclamation Wordpress Theme and Google Indexing Problem - Urgent Help
Friends, I gotta site http://tech-baby.co.cc
I recently downloaded Maxima theme from themebin.com. After successfully installing and managing the theme layout I got a problem.
Actually All in One Seo Pack is unable to write the Post Title in the Top of the Title Bar. Earlier I got the following format
Post Name | Tech Baby
But Now I am getting only
Tech Baby
For each and every post. Moreover with please refer to the following screenshot of google Index:
The second Result must be as follows:
Exclusive BlackBerry Storm Screenshots | tEcHBaBY
But it's showing only Tech Baby
The 3rd result is correct as it was indexed by google many days back. I am not sure, but think that some modification must be made in the theme, as this is the case with this theme only. Earlier (rather say 2 day before) there were No problem in writing the post title.
Since themebin.com is down due to Bandwidth Exceeded, I am uploading the theme to rapidshare for reference:
http://rapidshare.com/files/149654211/Maxima.zip (63KB)
Kindly help me please, i will be grateful to you
- Wishes
- MrinTech :)
mrintech is offline
Old 30-09-2008, 06:10 PM   #2 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default Re: Wordpress Theme and Google Indexing Problem - Urgent Help
Go to Dashboard>>Settings>>All in One SEO and check the box saying Rewrite Titles and then save the settings. And then check your posts for titles. If it does not work still, then report back.
navjotjsingh is offline
Old 30-09-2008, 07:27 PM   #3 (permalink)
Wise Old Mouse
mrintech's Avatar
This was checked from the First day when I installed AIOSEO... still rechecked it... Nothing happened...
- MrinTech :)
mrintech is offline
Old 30-09-2008, 07:39 PM   #4 (permalink)
I am Optimus Prime
Can you share your login details? I can check from within your wp dashboard for exact problem.
Don't worry...I am a old reputable(others call me) member.
Old 30-09-2008, 07:46 PM   #5 (permalink)
Wise Old Mouse
mrintech's Avatar
PMed
- MrinTech :)
mrintech is offline
Old 30-09-2008, 08:23 PM   #6 (permalink)
I am Optimus Prime
From what I have checked, there was a small bug in the theme's title - I fixed it. But still All in one SEO problem is not sorted out. And seems you are not alone. I checked at wordpress support forums - few users are facing same problem as you are. Latest version of all in one seo does not rewrite titles correctly.
I can suggest a much powerful plugin which can import settings from All in One SEO and offers much more features - http://techblissonline.com/platinum-seo-pack/
Its called Platinum SEO Pack. Trust me you won't be disappointed. It has more features than All in One SEO, imports All in One SEO settings and settings page is almost identical to all in one seo too.
I am using this plugin only on my 4 blogs.
Old 30-09-2008, 08:26 PM   #7 (permalink)
Wise Old Mouse
mrintech's Avatar
Ok I will do so.... I am viewing the Post titles at the top of title bar and you are saying that still there is problem... what is that
- MrinTech :)
mrintech is offline
Old 30-09-2008, 08:27 PM   #8 (permalink)
I am Optimus Prime
I have switched off All in one SEO Titles...that's all. Current titles are the one shown by your theme.
Old 30-09-2008, 08:28 PM   #9 (permalink)
Wise Old Mouse
mrintech's Avatar
getting this error see below:
- MrinTech :)
mrintech is offline
Old 30-09-2008, 08:50 PM   #10 (permalink)
I am Optimus Prime
Sorry abt that error..that was my mistake. Fixed. BTW I thought you were changing to platinum plugin? nevermind.
Old 30-09-2008, 09:00 PM   #11 (permalink)
Wise Old Mouse
mrintech's Avatar
yes i am installing right now and post as soon as I am done
Immense Thanks for your help and Concern
BTW it was hard to recall you from your name that who are you. You are the owner of NSpeaks. I read it Not regularly, but occasionally
Installed Platinum, rebuild the sitemap and resubmitted to google
Lets see what happens
- MrinTech :)
mrintech is offline
Old 30-09-2008, 11:59 PM   #12 (permalink)
I am Optimus Prime
Your post titles are still the old ones by the Blog Theme. There still seems a problem.
Old 01-10-2008, 12:46 PM   #13 (permalink)
Wise Old Mouse
mrintech's Avatar
Yup saw that. But Google is indexing the Posts Titles.
Is there any more need to modify the theme?
Here are the Google Indexing Screenshots for the Posts I wrote just after Installing the Platinum Plugin and the Tweaks (if any) You made:
Moreover a Plugin Named Wordpress Stats is also Not functionaing
Comments Please....
- MrinTech :)
mrintech is offline
How is my wordpress theme? victor_rambo Chit-Chat 8 27-08-2008 06:19 PM
Where to get Custom WordPress Theme done? drgrudge Chit-Chat 31 03-04-2008 12:20 AM
Should blogs be submitted to google for indexing? Sridhar_Rao Internet & WWW 2 18-12-2007 09:51 PM
how to prevent my page FROM GOOGLE INDEXING? kerthivasan Internet & WWW 11 05-03-2007 01:15 PM
Change wordpress theme. cybermanas Software Q&A 4 30-11-2005 11:11 AM
- by chris
