Old 29-09-2008, 07:36 PM   #1 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Vista Issue
1- i am using Security Toolkit software after install in vista when i open my secure drive and putting the password then press ok the error message comes ur password is wrong but when i logging in XP and check its works fine with same password.
2-Tweak Ui is not working in vista fine i use the tweak ui for changing my multimedia keyboard button shortcut means if any key in keyboard is for E-Mail then i assign this key for calculator.So there is any software for that.
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 01-10-2008, 12:56 PM   #2 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Thumbs down Re: Vista Issue
NO reply gr8
3-when i watching movie after 1 hour i comes to desktop my vista orb, Quick launch,startup program and desktop icon r not showing to me some time desktop icon appears but i click on just open nothing to show like when i open my computer its not showing the drive.Its not happen to watching movie if i left my pc for 1 hour and again i come and saw its in same condition then i log off the and problem solved.If i work normal on my pc just surfing on net more 1/2 than hour its happen so wat can i do format or switch to XP. man vista sucks me
Look down vista orb and start up
4-My all setting is rest like Turn off display i set 1 min after rest its come 20 min default
Dell 15z + WD 2TB
iPhone 4 32 GB
urgent vista issue sushantsaurabh Software Q&A 5 03-03-2008 11:36 AM
HELP: Vista firewall issue Faun Software Q&A 7 23-03-2007 01:14 PM
Vista Compatibility Issue........? satyamy Software Q&A 1 04-02-2007 03:22 PM
