| Forum |
#1 (permalink) |
Fullbring
when i inserted the DVD in my DVD-Writer it is invisible with free space/used space : 0 bytes... But its working fine in his laptop & his Desktop PC....wats the problem Is it possible 2 recover the files
Windows OS Calculator Bug Sqrt(9) - 3 = check the answer |
#3 (permalink) |
Democracy is a myth
Use ISO Buster...
If theres data, u'll get it...
"My opinions may have changed, but not the fact that I am right." "I'm never wrong. Once I thought I was wrong, but I was wrong" |
#4 (permalink) |
Same type of problem occurs with me but with data cd.
Cd is burned but no data is shown . I used a trial version of clone cd and made a clone of that cd and when i mounted that clone image it shows me the data. i don't know why it is not showing data on the orignal cd. software used -trial version of clone cd. and virtual clone drive |
#5 (permalink) | |
Fullbring
R u sure...it will work.. well i was thinking of using "recover my files..." app
Windows OS Calculator Bug Sqrt(9) - 3 = check the answer Last edited by Zangetsu; 30-09-2008 at 09:56 AM. Reason: Automerged Doublepost |
#6 (permalink) | |
Democracy is a myth
We used to use it to recover data from CD/DVDs having used to write multiple sessions. It happens sometimes in case of multi session disks that some sessions are suppressed, u can't c them but they are there. The trick comes handy in this type of problem too. Try the software and post ur experience.
#8 (permalink) |
Fullbring
Hey..i tried it yesterday..though it was ver1.8 (which i only have
work... it is showing Blank DVD only in ISOBuster
#9 (permalink) |
it seems your drive has become faulty. is it reading the digit or chip DVDs or any other DVD? this happens sometimes after the drive becomes old. my friend also experienced this problem for some time, then the drive stopped reading anything.
Digital Sheets Technology Blog AMD Phenom II X4 840, 4 GB RAM, MSI HD5670, Corsair CX400 PSU Nokia 5230 Canon IXUS 115 HS |
#11 (permalink) |
Jughead!!!
Since your drive shows 0 bytes it means the drive is not being able to detect the disc.
This happens sometimes, more often with less known branded dvds. Even brand new dvd drives fail to read dvds sometimes. The solution would be to use the dvd on another drive. Sometimes cleaning the lens also works. Putting the disc on the tray and inserting and ejecting the tray some 10 times also may work but try this only when the disc is damaged or the dvd lens is very dirty. |
#12 (permalink) | |
Fullbring
hey i tried as i,ve said
Windows OS Calculator Bug Sqrt(9) - 3 = check the answer Last edited by Zangetsu; 03-10-2008 at 09:49 AM. Reason: Automerged Doublepost |
#13 (permalink) |
then the disc must be faulty, try some other brand, moser baer is good in blank media but a bit expensive than ordinary ones.
#15 (permalink) | |
Fullbring
#16 (permalink) |
Legen-wait for it-dary!
Then your drive is faulty, connect it in a friend's place and use the same dvd to test. If it doesnt work still, update firmware or replace.
If the Start Windows Restart when Windows starts check box is checked Windows Restart will start automatically every time Windows is started. - Actual excerpt from a windows program help file |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| USBflash drive Data invisible | Invisible_Cop | Peripherals | 1 | 21-05-2008 09:12 PM |
| What Softwares/techniques data recovery professional use to recover data from HDD ? | CadCrazy | Software Q&A | 1 | 10-08-2007 10:01 AM |
| Invisible DVD RW | harryneopotter | Hardware Q&A | 11 | 04-07-2007 10:26 AM |
| How to apply invisible mode and detect who is invisible on the forum | Arsenal_Gunners | Tutorials | 82 | 28-02-2007 11:45 PM |
| invisible data | cyboincomp | QnA (read only) | 3 | 03-06-2006 03:54 PM |
