Old 27-09-2008, 09:32 PM   #1 (permalink)
Noobness unleashed....
Default Must Have Softwares on your USB Flash Drive
What softwares you carry on your pen drive?
lets post all we know of...
Shouldn't there be a sticky thread like this??
The best one i can find is "portableapps suite" which is availaible in 3 packs starting as low as 1 mb. The best part is it is completely free and regularly gets updated.
If you don't have the new U3 platform based USB flash drives, then you don't need to have the inferiority complex.
Last edited by prakash.gourav; 27-09-2008 at 09:41 PM. Reason: Automerged Doublepost
prakash.gourav is offline
Old 28-09-2008, 12:09 PM   #2 (permalink)
SuperMASSiVE
stonecaper's Avatar
Wink Re: Must Have Softwares on your USB Flash Drive
Well..There is Lupo Pensuite:http://www.lupopensuite.com/
or u can use winPenpack:http://www.softpedia.com/get/PORTABL...lash-1Gb.shtml
i Use The former One.....Its more stable and effective....
stonecaper is offline
Old 28-09-2008, 03:17 PM   #3 (permalink)
Default Re: Must Have Softwares on your USB Flash Drive
Antivirus solution-
avira free edition.
(instal directly to pen drive)
Spyware soln-
adware se personal
(copy the program files folder)
Old 29-09-2008, 07:04 AM   #4 (permalink)
The Black Waltz
Originally Posted by prakash.gourav View Post
Antivirus solution-
avira free edition.
Spyware soln-
adware se personal
These won't work on another PC because the registry keys need to be added as well.
#krow @ irc.freenode.net
Cool Joe is offline
Old 02-10-2008, 04:04 PM   #5 (permalink)
k i will try to verify that issue.
Meantime, this one is a hot tip.
If u want security on ur pen drive, try folder lock. I use version 5.9.0. Works both with vista and xp. Can lock files in the pen drive only after exporting the prog. To the drive through an option in interface. However, it is not a freeware.
Old 02-10-2008, 05:12 PM   #6 (permalink)
The Black Waltz
Yeah Folder Lock is a good program.
Cool Joe is offline
Old 02-10-2008, 08:42 PM   #7 (permalink)
New
New's Avatar
Calm Win Antivirus
New is offline
Old 03-10-2008, 12:57 PM   #8 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
ClamWin is not very good, but a good portable solution....
http://pleaseguide.me/
comp@ddict is offline
Old 03-10-2008, 08:32 PM   #9 (permalink)
@beta testing
The antivirus nd spyware i posted above are working dude
they wont be integrated to the shell on the other pc but u can start the program, scan pc or pen drive nd update them. i.e. They serve the purpose of portability
No mortal can keep a secret. If his lips are silent, he chatters with his fingertips; betrayal oozes out of him at every pore.
- Sigmund Freud
Old 03-10-2008, 09:00 PM   #10 (permalink)
www.system86.blogspot.com
devilinearth's Avatar
firefox portable
devilinearth is offline
Old 03-10-2008, 09:24 PM   #11 (permalink)
afonofa's Avatar
Question Re: Must Have Softwares on your USB Flash Drive
I'd like to add HiJackThis to this list.
@beta testing
Thanks. Avira free is probably better than Avast. But will the antivirus have realtime scanning of the pen drive? If a virus tries to copy itself to the pen drive will Avira protect against that(assuming its definitions are updated) or is it useful only for on-demand scans of an infected comp/pen drive?
afonofa is offline
Old 04-10-2008, 08:23 PM   #12 (permalink)
Distinguished Member
anandk's Avatar
WinVistaClub : 10 Most Useful Freeware Portable Applications
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 04-10-2008, 08:26 PM   #13 (permalink)
Debian Gnu/Linux User
Sathish's Avatar
defraggler..(with disk checking)
Living for Learning & Learning for Living
Sathish is offline
Old 04-10-2008, 10:21 PM   #14 (permalink)
The Black Waltz
@prakash.gaurav- Ok.
@afonofa- No they won't have real time scanning.
Cool Joe is offline
Old 05-10-2008, 12:30 AM   #15 (permalink)
Here are another 24 great portable softwares for ur pen drive...
http://www.downloadsquad.com/2008/09...sb-flash-drive
Some might get repeated... but some are really worth a try.... !!
Does spybot S&D comes in portable version mates???
- Sigmund Freud
Last edited by prakash.gourav; 05-10-2008 at 02:39 AM. Reason: Forgot the link... :D
Old 05-10-2008, 03:43 PM   #16 (permalink)
mad_max's Avatar
Folder lock and security c'mon man if its security you're after use true crypt and since i still use cafes i have kremlin secure recycle bin,err its not portable so ask someone who has thinapp to make it portable for you lol
mad_max is offline
Old 05-10-2008, 05:47 PM   #17 (permalink)
The Black Waltz
A portable version of Spybot SnD is available through the portable apps suite.
Cool Joe is offline
Old 05-10-2008, 09:32 PM   #18 (permalink)
@mad_max
surely u must be joking else u have never used folder lock then. It is "The Best" but of course it is a commercial programme.
- Sigmund Freud
Old 06-10-2008, 04:23 PM   #19 (permalink)
mad_max's Avatar
Its the best known with not so best known security issues.And i specifically said when it comes to security and just because something isn't free doesn't mean its good
mad_max is offline
Old 06-10-2008, 11:26 PM   #20 (permalink)
AFK
thewisecrab's Avatar
http://portableapps.com/
This should answer all your questions
Check out http://thefinal3rd.com, an Indian footie blog. Follow me on http://twitter.com/thewisecrab
Fishdumplings!! Duniya goal hai?
thewisecrab is offline
Old 07-10-2008, 12:25 AM   #21 (permalink)
must have read the first post dude.. lolzz
one platform certainly better than portable apps is Mojopac.
it is free for home users. cheers... Ppl term it even better than the U3
oKay this is probably the end of thread for me...
(coz i don't think if anything is left... almost )
Platform: mojopac, ceedo, portableapps, moka5, Portable ACE
list of portable softwares on wikipedia:
http://en.wikipedia.org/wiki/List_of_portable_software
Not satisfied...
convert urself almost any software to portable using "VMWare Thinapp" -commercial software
Portable softwares download on softpedia:
http://www.softpedia.com/get/PORTABLE-SOFTWARE/
Recommended by me:
platform: mojopac or ceedo
antivirus: nod32 portable
spyware: spybot S&D
- Sigmund Freud
Last edited by prakash.gourav; 08-10-2008 at 12:00 AM. Reason: Automerged Doublepost
Old 31-10-2008, 07:12 PM   #22 (permalink)
Unhappy Re: Must Have Softwares on your USB Flash Drive
plz help me anyone. plz. i have 120 GB flash drive of sony. its showing problem.
1)it cannot be formatted
2)the data which we store it became corrupted.
3)its reduces space. e.g. if we store 5 GB data .next time when we connect the flash drive data became corrupted & sometimes data automatically deleted. & space is reduces.it means its showing free space 120 out of 115. & data cannot be seen .
plz help me how to fix this problem
aniket_00772000 is offline
Old 31-10-2008, 08:38 PM   #23 (permalink)
|| तमसो मा ज्योतिर्गमय ||
DigitalDude's Avatar
120 GB flash drive???????
its probably a HDD
_
|U2311H|i5-760|P7P55D-E LX|Blackline 4X2GB DDR3|Callisto 60GB|2 X WD1002FAEX|GTX460 HAWK TA|S12II 520W|
|PC-9F|HD201|Abyssus|Blackwidow|Ikari Opti|Vespula|WD10EARS|Inspiron 640M|
DigitalDude is offline
Old 31-10-2008, 08:57 PM   #24 (permalink)
M3TAL H3AD M3
skippednote's Avatar
120GB flash drive........
I spit Rainbows.
skippednote is offline
Old 03-11-2008, 08:20 PM   #25 (permalink)
its probably a HDD
_
no dude. its a pen drive . small size.(120 GB) u have any idea how to fix the problem of it?
Old 04-11-2008, 05:10 AM   #26 (permalink)
jal_desai's Avatar
wiseval photophant -- for image renaming, resizing, converting...
TechExplorer.in
jal_desai is offline
Old 04-11-2008, 10:21 AM   #27 (permalink)
Jai Suresh
lywyre's Avatar
120GB Pen drive? Then its a fake. You have been duped.
lywyre is offline
Old 04-11-2008, 11:42 AM   #28 (permalink)
AFK
I didnt get this
Just because its small size doesnt mean its a pen drive...a pen drive AFAIK has a capacity of 10 GB after which it is no longer called a pen drive.
Is it a laptops HDD that fits in your pocket?
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
How to Use Pen Drive or Usb Flash Drive drive with NTFS topgear Tutorials 19 01-08-2008 07:40 PM
dont install OS on flash drive/damn small linux corrupted flash drive vish786 Open Source 2 28-07-2007 05:29 AM
Latest USB Drive softwares : U3 24online Random News 2 09-03-2007 11:50 AM
Need some suggestions about buying Pen Drive(flash drive) ~It_is_Andrew~ Hardware Q&A 16 14-09-2006 10:23 PM
