Old 26-09-2008, 08:27 PM   #1 (permalink)
MAK
MAK's Avatar
Default Widescreen problem. . .
My problem is that I have sum videos which are of 4:3 ratio and there is black strip at the top and bottom (I think they were reformatted from 16:9 to 4:3). .
So i wish to remove this black strip at the top and bottom so that i these comes fully on my screen
coz I have got widescreen monitor. . .
So. .This is actually wat i want
IS there any software for cropping/resizing video files ???????
Although i can view them by pan and scan in MPclassic nd showtime
but i dont want to do that....
MAK is offline
Old 26-09-2008, 09:43 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Widescreen problem. . .
You can just use Media Player Classic's Touch window from inside(or outside?) for instant stretching.
dheeraj_kumar is offline
Old 27-09-2008, 10:54 AM   #3 (permalink)
parthbarot's Avatar
no need to recrop it dude..just use players which provides feature for changing the aspect ratio at play time. say like.. VLC (Videolan.org) or Media player classic (K-Lite mega codec pack)..
VLC rocks btw
regards.
www.techlads.com
Paarth.
parthbarot is offline
Old 27-09-2008, 01:24 PM   #4 (permalink)
MAK
MAK's Avatar
I already told u guys dat i can zoom using MPclassic,showtime nd all. . .
but i dont want to do dat again and again whenever i play those videos
dats why i wanted such software
MAK is offline
Old 27-09-2008, 06:26 PM   #5 (permalink)
It would look UGLY. Seriously. Google for video cutting and crop software, and get them, but I repeat, they would look really stretched and ugly.
Old 27-09-2008, 08:44 PM   #6 (permalink)
MAK
MAK's Avatar
ok thnx
i will try it. . .
MAK is offline
Widescreen Problem! aditya1987 QnA (read only) 6 19-07-2008 10:19 AM
Problem with my New Samsung 943NMX 19" widescreen mrinal45245 Hardware Q&A 14 16-07-2008 03:48 PM
widescreen and integrated speaker problem Prathamesh_Mouse_Driver Hardware Q&A 5 15-02-2008 08:28 PM
AOC widescreen CRT??? Is it available? bikdel TVs / Monitors 6 22-09-2007 12:03 AM
widescreen LCD gksunil Hardware Q&A 3 23-04-2007 03:40 PM
- by chris
