Old 23-09-2008, 06:40 PM   #1 (permalink)
Yoda's Avatar
Default Seagate External HDD(40 GB) Not recognized
Hi Friends,
I've a 40 GB External HDD (Non-Branded). Its Seagate Momentus 4200.2 (40 GB) with "Gemini Casing". Its an old one and using it for years. I connect it via USB.
Now for more than a month I'm facing a problem. Whenever I Plug-in, I get a message "A porblem occurred during hardware installation. Your new hardware might not work properly". I tried all the USB ports in my PC and none of them is working.
But it work fine on other desktops and laptops except my PC. I use Windows XP SP3. I know its nothing to do with SP3 since the External HDD works with different desktops that has SP3.
Another point is Flash Drive / Pen Drive works fine in my PC.
SN: 3LE02VCW
Model: ST9402113A
Does anyone have a Solution ?
Regards
Rafales
Yoda is offline
Old 23-09-2008, 07:52 PM   #2 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
Default Re: Seagate External HDD(40 GB) Not recognized
Check ur system's usb ports..try by inserting in different ones.. If possible get a friends usb extension cable or the whole usb extension set.. Additionally check the power cable...
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline
Old 23-09-2008, 07:59 PM   #3 (permalink)
paroh's Avatar
Strange Problem. if pen drive is working that means port is not faulty.
Try manually installing USB mass Storage drivers from the device manager
paroh is offline
Old 23-09-2008, 09:10 PM   #4 (permalink)
Yoda's Avatar
external power supply not needed. once I plug-in the LED starts blinking Red and Green alternatively and it never stops blinking. I waited for long time but nothing happens.
but works perfectly fine in laptop or in another pc.
how to install it manually ?
Yoda is offline
Old 23-09-2008, 09:25 PM   #5 (permalink)
paroh's Avatar
Right click my computer->properties->hard ware->device manager->right click on the device and update
paroh is offline
Old 23-09-2008, 10:11 PM   #6 (permalink)
Yoda's Avatar
now I get this message...
I used Driver Genius Pro and found this error...
any solutions for this...
thanks a lot
Yoda is offline
Old 25-09-2008, 09:24 AM   #7 (permalink)
paroh's Avatar
right click on USB mass storage device and try to update driver.
paroh is offline
Old 25-09-2008, 07:13 PM   #8 (permalink)
15.0 GHz
VarDOS's Avatar
yeah my friend was facing the same prob....
U better try to change the USB cable.
It worked for my frnd
VarDOS is offline
Old 29-09-2008, 04:27 PM   #9 (permalink)
Yoda's Avatar
I did everything but nothing works. Its the USB device driver issue but don't know how to solve it.
I'm planning to re-install the OS.
Yoda is offline
Old 29-09-2008, 04:37 PM   #10 (permalink)
Sys***** IBM India.......
Try uninstalling SP3 and then repair the OS from XP CD .
rocky_om is offline
Old 30-09-2008, 04:46 PM   #11 (permalink)
Yoda's Avatar
Thanks for all the help and suggestions. Finally got it working with only 2 ports. re-installed usb drivers a few times and it worked.
Yoda is offline
Samsung or the Seagate HDD ! My Advice---Seagate is better. dabster Hardware Q&A 14 29-12-2008 08:12 AM
Seagate 750 GB External HDD for 4900 ? mananknl Hardware Q&A 18 10-08-2008 12:28 PM
160gb external hard drive not recognized parheez Hardware Q&A 1 07-07-2007 06:18 AM
- by Niilesh
