Old 22-09-2008, 09:09 PM   #1 (permalink)
The Sexy Beast
Unhappy PC normal boot problem
whenever i boot in windows after a couple of start up programs i get a blue screen and windows reboots.also the boot time has suddenly gone up windows boots only after atleast 50 scrolls.
this has happened after i got an error of windows\config\system file missing or corrupt earlier.my system was working fine until yesterday.
ratedrsuperstar is offline
Old 22-09-2008, 09:26 PM   #2 (permalink)
paroh's Avatar
Default Re: PC normal boot problem
Press F8 to display these options
1First try VGA mode if it work reinstall the graphic card drivers the latest one
Otherwise try
2 Last good know configuration
If it works its ok
otherwise try
3.Try safe mode and stop startup program from run->msconfig->startup
paroh is offline
Old 22-09-2008, 10:33 PM   #3 (permalink)
The Black Waltz
Check this out- http://support.microsoft.com/default...b;en-us;307545
It might be of help.
#krow @ irc.freenode.net
Cool Joe is offline
Old 22-09-2008, 11:02 PM   #4 (permalink)
The Sexy Beast
i think it's done by Worm.Win32.autoit.s coz when kaspersky detects it and i try to delete it.my system reboots.plz help me remove this ****
Old 23-09-2008, 12:19 AM   #5 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Scan your PC in safe mode and then try to delete all infected files. You can also try booting from a linux disk and scanning PC with Panda Antivirus for Linux.
As for corrupt windows\config\system file, Boot your PC with XP Installation disk and enter Recovery Consol and type following commands after giving your admin password:
cd system32\config [enter]
ren system system.old [enter]
ren system.alt systemalt.old [enter]
copy c:\windows\repair\system [enter]
copy c:\windows\repair\regback\system [enter]
Exit Recovery Console and Restart.
Quiz_Master is offline
Old 23-09-2008, 06:20 AM   #6 (permalink)
The Black Waltz
In your case, trying to remove the worm using Kaspersky in Windows may not be possible. The worm is also starting up with Windows and it's reluctant to stop. So what I suggest is, install Avast! with the latest updates. Schedule a boot time scan and restart. Before Windows boots, i.e when the worm hasn't loaded into memory yet, Avast! will perform a scan and you'll be able to remove the worm.
As for the system config file error, follow the link mentioned in my previous post.
Cool Joe is offline
Old 23-09-2008, 08:31 PM   #7 (permalink)
Can you post the exact error that you are getting?
vishrut is offline
Old 24-09-2008, 12:37 AM   #8 (permalink)
The Sexy Beast
the problem is solved thnx to a link i found by some googling but still the boot time is horrible.i guess after a defragmentation session it'll be alright.
does anyone think my HDD might be the cause for the System error.i have a WD 640GB HDD
Old 24-09-2008, 09:00 AM   #9 (permalink)
paroh's Avatar
Tell us how u solve the problem so that if any body encounter such type of problem, he can solve it.
paroh is offline
Old 24-09-2008, 10:43 AM   #10 (permalink)
The Black Waltz
I mentioned this link in my previous post.
It's for solving the system config file error.
Cool Joe is offline
Old 24-09-2008, 08:46 PM   #11 (permalink)
The Sexy Beast
i got the prob solved by only booting into the recovery console and doing nothing it stopped showing up afterwards.but i still feel my drive isnt functioning properly anyway to test it?????
Boot Problem the great one Software Q&A 1 24-03-2008 04:34 PM
Boot Problem Ranjya Hardware Q&A 6 24-12-2007 02:01 PM
boot from cd problem+reboot problem anilmm2006 Software Q&A 2 01-09-2006 11:03 PM
Boot Problem insane Software Q&A 5 22-03-2006 05:38 AM
boot up DVD ROM problem ?? Choto Cheeta Software Q&A 3 09-01-2005 10:23 PM
- by Niilesh
