Old 21-09-2008, 12:48 AM   #1 (permalink)
Kcots Hserf
trublu's Avatar
Default How to change System Volume Information attributes?
Yes,how to do it? whenever i check "show hidden files and folders",the system vol. information folder in C: shows up,even though i haven't unchecked "Hide protected OS files". Any help?
ASUS K53SM-SX0101D | Samsung Wave 525 | Canon EOS 1000D | 18-55 mm | 50mm f1.8
Registered Linux User #471793
trublu is offline
Old 21-09-2008, 08:28 AM   #2 (permalink)
AFK
thewisecrab's Avatar
Default Re: How to change System Volume Information attributes?
What attributes do you want to change? It is a system folder mind you... one wrong move and everything goes kaput
I advice against it....
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 21-09-2008, 12:13 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Nah, files in SVI are perfectly safe to delete. Go to any drive, right click SVI, click properties. In sharing tab, Tick whatever box is available and click okay. Repeat on all drives. Now you can delete the files inside. If you cant, restart the comp, and now you can.
dheeraj_kumar is offline
Old 21-09-2008, 03:03 PM   #4 (permalink)
Kcots Hserf
trublu's Avatar
Yet another query:
The SVI folder in C: can be opened.But when i double-click the same folder(SVI) in other drives, i get an error "Access is Denied". Is something wrong?
trublu is offline
Old 21-09-2008, 06:01 PM   #5 (permalink)
The Black Waltz
There's nothing wrong. Just right click on the SVI folder, click on "Properties" and go to the "Security" tab. Click on "Add". Enter your user name. Click on OK twice. You'll now be able to open that folder.
#krow @ irc.freenode.net
Cool Joe is offline
Old 22-09-2008, 09:50 PM   #6 (permalink)
@trublu
Do what I said for SVI in all drives.
Old 25-09-2008, 09:04 AM   #7 (permalink)
paroh's Avatar
Open windows explorer go to Tools->Folder Option->View and check the last one use simple file sharing(Recommended).
And after that right click on System Volume Information to change its attributes
paroh is offline
Old 25-09-2008, 10:02 AM   #8 (permalink)
^^ yeah I forgot that step, thanks
don't want system volume information shidhin4ever Software Q&A 4 13-05-2007 10:46 PM
AV finds trojan in C:\System Volume Information b_man Software Q&A 2 09-02-2007 12:41 AM
virus in System volume information folder Shikhar Software Q&A 3 16-08-2005 08:01 PM
- by Niilesh
