Old 20-09-2008, 09:59 PM   #1 (permalink)
Default DOS Bootable USB
I want to boot into my P4 system using a USB drive so that I can execute my DOS programms on it. SO if someone has any idea please help me out....
abhijeet.k1810 is offline
Old 21-09-2008, 07:14 AM   #2 (permalink)
Default Re: DOS Bootable USB
does ur bios support booting from USB ..if yes then................
http://www.bootdisk.com/pendrive.htm
create a new folder after making your drive bootable...put the DOS files into it...
you wont be able to run the USB drive if it is NTFS...........
Regards
imageek is offline
bootable cd to bootable pen drive dare_devil Software Q&A 3 06-02-2008 07:17 PM
Combining Non-Bootable & Bootable CD Iso's into a DVD arnold Software Q&A 3 26-12-2007 07:28 PM
Xp bootable DVD with SP2 User Name Software Q&A 11 07-10-2007 08:36 AM
win xp bootable cd??? abhinandh Software Q&A 3 19-07-2007 07:38 PM
Convert 2 bootable windows CDs into 1 bootable DVD thetopcyborg Software Q&A 1 13-09-2006 07:36 PM
- by Niilesh
