Old 17-09-2008, 01:39 PM   #1 (permalink)
goldie999's Avatar
Question EXPLORER.EXE problem
Hi Frnds.....
Pls help me wid this problem.....
I just cant access any folders and/or files from the dvd,cd and any removable disc like pendrives.
An error like "the referenced memory location cannot be found...EXPLORER.EXE and APPLICATION.EXE error"
Later when i again access those folders, it opens up but the same thing happens for folders inside...
I have scanned using AVAST antivirus but didnt find any virus..
There is no such problems wid my HDD...only wid the DVD/CD & Pendrives...
PLS Solve this....its really irrating me
goldie999 is offline
Old 17-09-2008, 02:20 PM   #2 (permalink)
Ballack Junior
tuxybuzz's Avatar
Default Re: EXPLORER.EXE problem
i had the same problem..this happened to me once avast deleted the explorer.exe file in my usb disk claiming it to be a worm..but then i use linux too so i backed up my data from there and formatted...
tuxybuzz is offline
Old 17-09-2008, 02:55 PM   #3 (permalink)
Project Halcyon V2.0
tkin's Avatar
Its either a virus or a trojan.
Do these:-
1.Download Spybot Search And Destroy and install it, then update it(must) and scan.
http://www.safer-networking.org/
2.Start you PC in safe mode and see if the error still occures, if it doesn't that means there is a problem with your start-up softwares remove any that you don't need and reinstall the others.
If the error still occures reinstall(repair) XP as it indicates EXPLORER problem.
P.S- My minds telling its a start-up software, any new ones you installed/reinstalled lately?
Project Halcyon v2.0:
[i7 2600k|Asus Z68 VPro|Vengeance 2x4GB|MSI GTX580 Lightning]
[TX 750v2|Seagate 500GB+WD Cav Black 1TB|CM HAF 912 Adv]
[Logitech G110|G500|Adata/750GB+WD/500GB USB 3.0]
[APC 1100VA|XBox 360 Controller|Noctua U12PSE2]
[Siberia Soundcard(Xear 3D)|Koss Portapro|FiiO E6]
[Audio Technica M35|PL30/EOL'ed]
tkin is offline
Old 18-09-2008, 01:14 PM   #4 (permalink)
goldie999's Avatar
Thnks " thkn"
for ur suggestion....
i will see if ur soln works.........
"ASK.......BELEIVE.........RECEIVE"
Problem with explorer MAK Software Q&A 3 10-07-2008 11:26 PM
Serious Problem Need help (EXPLORER) max_demon Software Q&A 8 08-05-2007 11:36 PM
Problem with explorer manuajith Software Q&A 4 05-04-2007 05:25 PM
problem with explorer Samish Tutorials 2 06-11-2006 08:26 PM
problem with explorer njm Software Q&A 2 12-09-2006 01:37 PM
- by Niilesh
