Old 13-09-2008, 03:04 AM   #1 (permalink)
Lightbulb Strange Display problem in vista
Hi
I have windowsvista with a viewsonic lcd
The problem is that all-of-a-sudden the screen started having fast-moving pixels like in the pics:
(using snipingtool)
(using printscreen key)
What i can tell till now:
~the pixels where everywhere and increased wherever moving display(like usage bar, movie playing)
~this problem occured only once before, weeks ago
~both of the times i was playing movie on kmplayer
~turning lcd off-on didnt solve problem,,so, i think not a fault of lcd
~i turned pc to 'sleep' and on wake up, everything fine and the problem did not come again, wierd??
PLEASE HELP (any future forecasting?? virus??)
saurabhsun is offline
Old 15-09-2008, 09:24 AM   #2 (permalink)
paroh's Avatar
Default Re: Strange Display problem in vista
1)First try to update ur graphic card drivers to the latest one. if it works its ok
otherwise
2)Try to change the resolution and the refresh rate of ur monitor
paroh is offline
Old 15-09-2008, 09:56 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Reset your monitor settings to factory defaults and that may work.
desiibond is offline
Old 15-09-2008, 11:34 AM   #4 (permalink)
Ballack Junior
tuxybuzz's Avatar
refresh rate seems to be the culprit
tuxybuzz is offline
Old 15-09-2008, 12:00 PM   #5 (permalink)
LCD ???
refresh rate >>>
lolz...
Faun is offline
Old 15-09-2008, 01:03 PM   #6 (permalink)
Rubik's Uncle!!
Charan's Avatar
This is a driver issue. I too face a similar but more severe problem while playing movies in my laptop. The display completely goes haywire and I have to put the lappt on standby and wake it up again.
BTW whats the gfx processor you have ?
Charan is online now
Old 19-09-2008, 05:20 PM   #7 (permalink)
i have nvidia geforce 8500gt 512mb
the drivers were up-to-date
the monitor is viewsonic vg2030wm suppoting 59-60hz refresh rate which is currently set at 60hz
is it ok??
what would be difference at 59hz???????
Old 22-09-2008, 09:13 AM   #8 (permalink)
paroh's Avatar
Try to change ur OS?
or look that ur dvi, hdmi or vga is good enough?
paroh is offline
Old 22-09-2008, 03:14 PM   #9 (permalink)
ECE0105's Avatar
Same problem happening with me as well.
XFX 8600GT (512Mb DDR2) and Samsung 19" Widescreen.
After I get such pixels, the screen turns blank and get an error that the Display Driver service failed and has been restarted. System freezes after 1 hour of use, then again, no such problems in XP, unless Playing NFS Carbon, Hitman Blood Money and GTA San Andreas.
I guess problem is with the Graphics Card. Need to give it to the Service Center so that they can check and let me know...
Some of the happiest people in the world do NOT have Everything... They just make the Best of Everything life brings their way... So, Stay HaPpY.... Smile Always.... :-)
ECE0105 is offline
Strange Temperature Display ??? bajaj151 QnA (read only) 29 24-09-2007 12:53 PM
Strange Problem of display card System Of A Down Hardware Q&A 1 22-06-2006 04:51 PM
Strange! very strange..!! Where is the Problem ? Ricky QnA (read only) 8 11-04-2005 04:14 PM
- by Niilesh
