Old 09-09-2008, 12:44 AM   #1 (permalink)
Exclamation explorer restart problem, taskbar disappear
i have a problem. i am using a vista ultimate with sp1.
some time explorer crash and restart but taskbar does not reappear. computer window opens which shows all drives, etc. and task manager shows explorer.exe is runing. when i close the computer window, exploere.exe also disappears from task manager.
i have tried to restart explorer using task manager but still the same result. computer window open and taskbar still dont.
i have to log off or restart computer to get the taskbar back.
any help...........
rahuljin is offline
Old 12-09-2008, 10:33 PM   #2 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Default Re: explorer restart problem, taskbar disappear
Try SFC if dat works in Vista
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 15-09-2008, 07:46 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
Check Vista Explorer Crashes Frequently.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 15-09-2008, 08:07 PM   #4 (permalink)
moshel's Avatar
hit the windows key on the keyboard......
moshel is offline
Old 15-09-2008, 08:09 PM   #5 (permalink)
God of Mistakes...
Garbage's Avatar
for what ?? :O
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 15-09-2008, 08:56 PM   #6 (permalink)
moshel's Avatar
Originally Posted by Garbage View Post
for what ?? :O
to bring up the taskbar....it happens sometimes in xp too when the taskbar crashes, explorer.exe restarts but u dont see the taskbar....most of the times it is solved by pressing the windows key on the keyboard.
moshel is offline
Problem in displaying LAN icon in taskbar Hari_04415 Software Q&A 3 18-08-2007 05:57 PM
Win 98 Taskbar problem. sr123 Software Q&A 2 20-06-2007 08:31 PM
strange problem in xp, CTRL+ALT+DEL does nt brin d taskbar.. dkd903 Software Q&A 7 07-01-2006 11:24 AM
Taskbar problem ra_sriniketan QnA (read only) 4 20-08-2005 07:45 PM
Problem With Taskbar neerajvohra QnA (read only) 1 29-03-2005 09:44 AM
- by Niilesh
