Old 08-09-2008, 09:34 PM   #1 (permalink)
Default spyware again and again..!
hi guys...i hv a prob...
3-4 days ago i installed spyware doctor...scanned and found a lot of threats...it cleaned my pc and said that it is now threat free.!!
bt since thn everyday whenever i scan my pc with spyware doctor...it always tends to find some threats..i wonder frm whre are thse threats coming evryday...i mean...if one day it says tht im clean...thn hwcome the very next day i find threats all over again.!
im uploading two files, one is the screenshot and the other is the report.....pls chk it out and help me..
thnks in advance..!
manan
magneticme200 is offline
Old 09-09-2008, 08:44 PM   #2 (permalink)
Default Re: spyware again and again..!
pls comp champs...help..!!
Old 10-09-2008, 09:36 PM   #3 (permalink)
The Black Waltz
Why don't you post your HijackThis log here?
#krow @ irc.freenode.net
Cool Joe is offline
Old 10-09-2008, 10:16 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Try this:
How To Do Effective System Scanning
ravi_9793 is offline
Old 15-09-2008, 08:22 PM   #5 (permalink)
Wise Old Mouse
mrintech's Avatar
Hope this Helps: http://tech-baby.co.cc/2008/09/13/be...or-home-users/
mrintech is offline
Old 22-09-2008, 12:19 AM   #6 (permalink)
1st u should close that soft through Task manager and then source that soft place rename that folder and delete don't forget to remove that program from Start up
teamonesolutions is offline
Old 22-09-2008, 01:09 AM   #7 (permalink)
use spyware terminator... free and best...
omega12 is offline
Old 22-09-2008, 01:19 AM   #8 (permalink)
Wise Old Mouse
mrintech's Avatar
I already gave you this link: http://tech-baby.co.cc/2008/09/13/be...for-home-users
Use a-sqaured and spyware terminator and all spywares are gone... bet you
mrintech is offline
Warning! spyware detected on your computer! Install an antivirus or spyware remover t Invisible_Cop Software Q&A 3 01-08-2008 08:37 PM
Spyware !!!!!!!!! Binay 007 QnA (read only) 11 20-02-2007 01:40 PM
SPYWARE HELP!!!!! adityaksharma QnA (read only) 12 12-06-2005 11:59 AM
which is the best anti spyware or spyware removal tool?????? harry_nitish QnA (read only) 2 17-05-2005 09:29 PM
HELP!!!!!!!! Spyware????? prajneet QnA (read only) 14 10-08-2004 11:36 AM
- by Niilesh
