Old 08-09-2008, 07:31 PM   #1 (permalink)
Exclamation Help..forget Zip Password....
frnds
i hav forget password ofa zip which contains some important data...
plz help me retiving it....
i hav tried googling there r some softwares like advanced archive password recovery,.... etc.. which software of them is best.....
Is there any other method to retive password......
nishith is offline
Old 08-09-2008, 08:57 PM   #2 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: Help..forget Zip Password....
Sorry, But I Had A Software Called RAR Password Recovery U Can Also Try Similar Software For Zip
VarDOS is offline
Old 09-09-2008, 07:40 PM   #3 (permalink)
are bhai ......... plzz share ur knowledge.............
nishith is offline
Old 10-09-2008, 08:51 AM   #4 (permalink)
raksrules's Avatar
Dont know whether this is the best or not, but i have used this software and i feel its quite good. But let me warn you that this (and for that matter any other zip password recovery ) software uses hell lot of time depending on how complex the password is. It is better if you are aware about some parts of the password or whether everything is in CAPS or small or whether there are any numeric or special characters in it.
Incase you dont know anything about the password, use the brute-force attack (but before this do try the dictionary attack) and it will take its own sweet time to retrieve the password. Also the speed of these tools are very much dependant on the processor speed and available resources. Better the resources you have, more the passwords it will try per second and less the time it will require for you to get the password.
raksrules is offline
Old 17-09-2008, 08:45 PM   #5 (permalink)
thankx bhai for ur help......
am tryin brute force attack .........
nishith is offline
Old 19-09-2008, 07:09 PM   #6 (permalink)
I Once Had The Same Problem Forgetting Passwords To Zip Or Rars.
Progs Mentioned Above Will Try To Find 40-50 Pass/sec On Core2duo E6600 2gb Ram When You Start It Will Keep On Going Down As They Start Trying Larger Passwords. It Will Take Ages If Your Pass Is Something 7-8 Digits Long. So Try To Mediate And Think Over And Over To Remember Your Password
RAJEEV TUTEJA is offline
Old 20-09-2008, 06:56 AM   #7 (permalink)
"Aal Izz Well"
Krazzy Warrior's Avatar
^^+1..
http://twitter.com/krazzywarrior
Krazzy Warrior is offline
Old 20-09-2008, 09:56 PM   #8 (permalink)
good for u
come n join me next month
bty u just might recollect the ?word by that time
Old 21-09-2008, 06:13 PM   #9 (permalink)
P_A_3DT.part1 is a RAR file I downloaded from rapidshare. It is password protected and I can't open. Please any one help me.
gajananavaze is offline
Old 22-09-2008, 10:06 AM   #10 (permalink)
brute force sucks....*****.......
nishith is offline
Forget the Z5500. This is MORE like it sreenisatish Hardware Q&A 16 02-05-2009 11:47 PM
Want to get more traffic to your site?Dont forget these mayanks_098 Tutorials 19 14-01-2008 05:33 PM
Forget Password boosters Software Q&A 14 31-07-2007 04:54 PM
forget my xp password saurabh kakkar Software Q&A 2 08-04-2007 09:32 PM
Forget half life 2, forget doom 3 borg QnA (read only) 20 14-02-2005 08:29 PM
- by Niilesh
