What backend are you gonna use? asp/php have database support. Read your book(you should have one) for more details. You can learn the basics from
http://www.w3schools.com/ and search google for lots of tuts "asp database" and "php database"
For the frontend, either generate html pages or have an application in case of asp to connect to the server.
