Old 06-09-2008, 07:32 PM   #1 (permalink)
mad1231moody's Avatar
Red face BIOS Problems!
One annoying problem is bothering me every time I boot my PC. The error is CMOS setting wrong, Press F1 to load default settings. When I do that my setting are dated back to June 2004, and my start button tells "New Programs Installed" . My motherboard is ASROCK 845G and I think that it is BIOS prob. Please tell me how to flash the BIOS so I can do away with this problem
mad1231moody is offline
Old 07-09-2008, 07:58 AM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: BIOS Problems!
change your cmos battery. five bucks for one at any watch repair shop.
dheeraj_kumar is offline
Old 07-09-2008, 10:35 AM   #3 (permalink)
OK, i gotta see inside my cabinet for it. But are u sure that this is the cause
Old 07-09-2008, 08:12 PM   #4 (permalink)
Yes. Quite positive. For an extreme case, you may need to replace your cmos chip itself, but I cant think of a situation where it can lead to a checksum error.
Post ur mobile internet queries, problems n problems here sourishzzz1234 Buying Advice 2 19-01-2008 07:34 PM
Bios Help codename_romeo Hardware Q&A 5 08-12-2006 02:22 AM
Problems and more problems with Linux phreak0ut Open Source 25 16-11-2006 09:38 PM
Bios godsownman QnA (read only) 13 19-06-2005 09:19 PM
BIOS The Incredible QnA (read only) 12 02-06-2005 12:46 PM
- by Niilesh
