Need help to configure my pc better......
Hi all..
My PC configuration is in my siggy.. I didnt overclock any thing. When I run games, in Vista, some of the games give a slight choppy performance. Even the older ones too. The Vista index score is 5.3.
Processer: 5.3
RAM: 5.9
HDD: 5.9
Business GFX: 5.9
3d GFX: 5.8
These are what I remember. Is it my Processer that is weak? The games does not run smooth. Is there anything to tweak or better the performance? The RAM modules are in dual channel. I dont want to turn off the effects though. I just want to know if there is anything to increase the performance. any tips/overclockings etc...
I am running my pc on the 400W stock PSU that came with the cabinet (iball Benz). How to calculate how much this PSU can handle? what are the parameters? I am planning to get an extra HDD. How to determine the limit? Can I overclock my gfx card (8600 GT)/CPU on this PSU? What are the factors that I should keep in mind?
Thanks in advance
My config: AMD Athlon x2 5600+, Asus M2NPV-VM, Transcend 2x1GB 800MHz, XFX 8600GT 256MB, Seagate 250GB SATA2 + Seagate 500GB SATA2, LG 1752s LCD, Sony DRU v200A DVDRW, Logitech MX518, iBall Benz cab
