Old 03-09-2008, 12:36 PM   #1 (permalink)
JojoTheDragon's Avatar
Question BOOT.INI Missing. HELP!!!
Yesterday I reformatted my hard disk. Installed Win XP SP2. After that I installed some softwares. I then it installed Windows Vista Ultimate. Both operating system were working fine. But after installing vista sp1, win xp disappeared from the boot screen. I then used Easy BCD 1.7.2 and downloaded NDETECT and ntldr. And copied them to the drive where I installed XP. And used easyBCD to make a new entry in the boot screen for win xp. Now when I select XP in the boot screen it shows Boot.ini missing NTDETECT Failed. Any body knows how to solve this. I am really confused. PLZZZZZZZZZZZZZZ Help
| Steam: jojothedragon | Origin : jojothedragon | PSN : jojothedragon |
TDF @ Steam
Get 2GB of free cloud space : http://db.tt/OJKPcZnY
JojoTheDragon is offline
Old 03-09-2008, 02:23 PM   #2 (permalink)
Jai Suresh
lywyre's Avatar
Default Re: BOOT.INI Missing. HELP!!!
Boot from WinXP boot CD and goto Recovery Console. You will be prompted to choose your Windows XP Installation from a list (if more than one XP installation is installed) ... Choose your installation and enter the adminstrator password. You will get the command prompt. Now type fixboot, this will create a new boot.ini for your installation. (type help to get list of available commands and /? to get help for a particular command eg: fixboot /?). When finished type EXIT to restart your computer in normal mode.
Caution: This could make Vista unusable, you may have to follow similar steps for Vista, if it gets messed up.
lywyre is offline
boot.ini missing bharat_r Software Q&A 1 09-10-2007 11:40 PM
If Vista is missing, as an option, in a Multi-Boot Computer. anandk Tutorials 15 13-09-2007 10:21 AM
Windows XP Missing Boot!!!! caje143 Software Q&A 3 27-06-2007 11:23 AM
Boot.ini tab is missing abhijitroy Software Q&A 1 12-02-2006 02:13 PM
Boot Loader Missing Help! Tech&ME Open Source 7 26-12-2004 10:53 PM
- by Niilesh
