Old 02-09-2008, 08:53 AM   #1 (permalink)
Question How to Recover Missing Space from USB Drive
Hi Members,
I have a 1GB ThumbDrive USB Storage from Trek. It had some built in password protection/encryption software(ThumbDrive 2 Smart Login). It happened that I forgot the password. In order to access the drive I deleted the encryption software and formated the drive. After this, the drive shows just 3MB of space. The rest(which I think was the encrypted area) is lost.
I request the members to advice me on how to recover the missing space.
This is the link of the product with an exception that mine has "HP" instead of "ZAP" on it!!
http://www.trekstorusa.com/thumbdrive_zap.htm
Thank You
srk006 is offline
Old 02-09-2008, 01:33 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: How to Recover Missing Space from USB Drive
low level formatting may help.
http://h20000.www2.hp.com/bizsupport...X-UNITY-I23839
or any tool from http://hddguru.com/
dheeraj_kumar is offline
Old 02-09-2008, 07:41 PM   #3 (permalink)
@dheeraj_kumar
Thanks for the reply
I tried the hp tool as well as HDD Scan. Even after erasing with HDDScan and reformatting it still shows 3MB. Any other tool?
Update:
I think I need a tool like 'HDD Capacity Restore Tool' that can restore factory capacity for USB drives. Is there any available out there?
srk006 is offline
Old 03-09-2008, 08:59 AM   #4 (permalink)
have you tried
http://hddguru.com/content/en/softwa...l-Format-Tool/
it says it recertifies the drives too. try that.
Old 03-09-2008, 05:50 PM   #5 (permalink)
@dheeraj_kumar
I tried the Low Level Format tool also. But no luck. It says "This device cannot be accessed because its smaller than 65535 sectors". What to do now?
srk006 is offline
Old 05-09-2008, 03:56 PM   #6 (permalink)
Guys, Any more suggestions regarding this?
srk006 is offline
Old 05-09-2008, 06:55 PM   #7 (permalink)
Dunno then, wait for other members' replies.
how to recover space in harddisk? rohitr Software Q&A 4 25-12-2007 12:02 PM
Missing space!! sagar_coolx Software Q&A 2 08-12-2007 01:08 PM
HDD space missing sujit.pawar Hardware Q&A 9 25-03-2007 09:24 PM
How to recover 2 GB space that HDD takes choudang QnA (read only) 13 24-01-2006 08:38 PM
hard disk space missing!! arcticflare QnA (read only) 9 07-06-2005 09:12 PM
- by Niilesh
