Old 28-08-2008, 04:41 PM   #1 (permalink)
Exclamation Audio problem..
I've got a problem with headphones plugged into my laptop Inspiron 1520.I can hear sound only through the right speaker.There is NO PROBLEM with normal playback with laptop speakers.I've tested 2 or 3 headphones working perfectly in other systems on my laptop, all of them giving me the same problem.
Plzz help..
gateclaw is offline
Old 28-08-2008, 08:04 PM   #2 (permalink)
moshel's Avatar
Default Re: Audio problem..
did u try by pushing in the pin harder or pulling it out just a little bit. there might be some loose connection in the socket..
moshel is offline
audio problem balavinayak Hardware Q&A 1 08-01-2008 04:47 PM
Audio Problem santoshp QnA (read only) 3 22-09-2006 01:39 PM
XP 64 bit problem with audio..help me..plz hermit Software Q&A 3 18-07-2006 08:27 PM
Audio Problem !! nipun_the_gr8 QnA (read only) 8 18-06-2005 12:02 PM
audio problem in 98 parth QnA (read only) 2 29-03-2005 11:12 PM
- by Niilesh
