Old 27-08-2008, 11:47 PM   #1 (permalink)
Default office problem
i am using Xp 2 when i am installing office my system is restarting my ram is 1gb and hd is 160gb intel dual core i am using hardare any tell wat the problem i am using office 2007 pro
rvk0487 is offline
Old 28-08-2008, 12:00 AM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: office problem
ur problem is not clear 2 me............I mean what is ur prob??
Ur PC shud restart aftr installing Office to complete installation..........its common........
plz desribe ur problem in brief..........
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is offline
Old 28-08-2008, 12:14 AM   #3 (permalink)
Elevating Humanity
The Conqueror's Avatar
Your Problem isnt clear to me either.Please explain in more detail.
Regards,
The Conqueror
The Conqueror is offline
Old 28-08-2008, 10:58 PM   #4 (permalink)
Just a though..
In windows registry there's a setting as 'Automatically restart windows when explorer crashes'.
It's better to keep it disabled.
I guess one can use third party utilities for tweaking XP settings that should have some option to keep this setting disabled.
patkim is offline
Old 29-08-2008, 08:33 AM   #5 (permalink)
Amir.php's Avatar
^^i will not prefer to desable it.
it is better for the system helth to restart when any crash occured.
Regarding the problem i think you have missed out some necessary os files.
sp2 is very necessary and also .net framwork.
Also check the same installer on other system. it may be faulty.
Amir.php is offline
Old 29-08-2008, 12:56 PM   #6 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
I would not automatically restart when explorer crashes, since the bsod which pops up can tell us what exactly the problem is. If it restarts immediately, we cant see where the error is.
dheeraj_kumar is offline
MS Office problem bhutbhut Software Q&A 9 03-07-2008 11:58 AM
ms office problem aneesh kalra Software Q&A 4 22-01-2007 07:44 PM
MS office problem Manish_1234 Software Q&A 2 04-12-2006 06:42 PM
Office Problem shwetanshu Software Q&A 4 20-03-2005 10:21 PM
office assistant starting problem in office 2000 madan Software Q&A 1 13-01-2005 12:40 PM
- by Niilesh
