Old 26-08-2008, 07:25 AM   #1 (permalink)
Default infected by TROGEN, pls guide me to sort it out
hi experts,
one of my relative told to me last week that, he got infected by TROGEN. i adviced him that, i can give anti virus, so he came to me with hin pendrive.i have copies avast on it.when i connected, my avast warnd me that, it migh having trouble.i have removed. and after shutting down,the next starting onwards, my avast asking to do a through scan by rebooting. and now, i am not able to open Yahoo messenger too, where i miss lots of work by this.
could any of you, be kind to guide me to sort out my problem with TROGEN, by your guidance and by sharing good trogen removers.
thanking you in advance
mobileman
mobileman is offline
Old 26-08-2008, 09:36 AM   #2 (permalink)
Default Re: infected by TROGEN, pls guide me to sort it out
Download the trial version of Kaspersky Antivirus 2009 and scan your PC for threats.
cool_techie_tvm is offline
Old 26-08-2008, 12:18 PM   #3 (permalink)
AFK
thewisecrab's Avatar
Scan your PC using Online scanners Or Download and install BETTER antivirus
You can find online scanners here: (They generally detect, not remove the virus)
http://thinkdigit.com/forum/showpost...5&postcount=36
Links to better antivirus softwares
http://thinkdigit.com/forum/showthread.php?t=94072
And its "trojan", not "trogen"
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 26-08-2008, 11:14 PM   #4 (permalink)
My Dear Friend thewisecrab,
thanking you for sharing the link. and also, for i would like to apologize the typo occurred.
and let me try to download few from the link.
Old 27-08-2008, 04:07 PM   #5 (permalink)
I suggest you use the AVG v8.0 with the latest updates. Avast might be a great anti-virus program but misse out on some trojans and viruses for reason yet unknown to me.
xander.tom is offline
Old 28-08-2008, 01:09 AM   #6 (permalink)
Elevating Humanity
The Conqueror's Avatar
I Suggest that you get Kaspersky Internet security2009/Kaspersky Antivirus 2009 OR NOD32 antivirus as they are one of the best security solutions available.
Regards,
The Conqueror
The Conqueror is offline
Old 29-08-2008, 11:09 PM   #7 (permalink)
Default Re: infected by TROJEN, pls guide me to sort it out
my dear friends,
well i have got the name or worm is Win32:Rootkit-net
be kind t o give a solution. coz, i am not interested to Format my hdd, where my E partition is containing lods of downloaded items.
be kind to give an appropriate remedy.
really i am in need, as in danger
mobileman
Old 31-08-2008, 08:49 AM   #8 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Its a spammer rootkit,
http://www.google.com/search?num=100...it&btnG=Search
dheeraj_kumar is offline
what is this problem!!!!!!!can any one sort it out plz.. karthik55859 Hardware Q&A 15 12-06-2008 05:56 PM
Sort it out chitra_654 Mobiles and Tablets 12 06-02-2008 02:03 PM
sort +r ?? ravix Open Source 1 07-07-2006 08:30 PM
sort out my prob.. abhishekkalra QnA (read only) 1 18-12-2005 07:43 AM
Sort in MS - Excel godsownman Software Q&A 5 08-08-2005 11:53 PM
- by Niilesh
