Old 24-08-2008, 04:10 PM   #1 (permalink)
Stay Silent!
enticer86's Avatar
Default WinXP installation problem :(
Friends help me out.
Yesterday while booting up my PC, it was very slow and showed me the option viz Start normally, safe mode etc. I tried all options but it works fine till the log-in to windows page. After that it restarted automatically and repeated this.
So after trying everything, I formatted the PC and reinstalled WinXp SP2.
After using the computer for 1 hour(ie, after installing all the softs. and stuf) i turned it off. After rebooting, i again got the same problem.
After repeating this ie formatting and reinstalling for 4 times, i deleted all the partitions and everything, and recreated the partitions while installing windows.
Now the trouble is:
1. WHy is this happening? There is no virus as per Avast! scans. Will I be able to reboot safely again?
2. While recreating NTFS partitions, i now see that about 10% of the disk space is "used" in properties. Why is it so? There are no hiddens files etc.
Pls help asap
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
enticer86 is offline
Old 24-08-2008, 04:13 PM   #2 (permalink)
Default Re: WinXP installation problem :(
Did you add any new hardware?
ThinkFree is offline
Old 24-08-2008, 04:17 PM   #3 (permalink)
Stay Silent!
enticer86's Avatar
NOthing at all. Its happening out of the blue.
i just realised its MFT
I saw me running,
Old 25-08-2008, 09:13 AM   #4 (permalink)
Be Healthy, Keep Smiling
Kaushal Hiwarkar's Avatar
Plz Check ur Ram,
Kaushal Hiwarkar is offline
Old 25-08-2008, 10:57 AM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
Few possible problem by their importance,
* System Temp
* Hardware connectivity issue (due to dust or lose connect)
* PSU failing provide enough juice
* RAM Issue
* WinXP critical files are missing / Malware infection / BIOS issue
Now how do you troubleshoot them ??
System Temp
Make sure your processor fan is spinning, get in to bios and keep the PC on for certain time, then view the temp of system (CPU / NB / MOBO)...
Are they under limit ?
If your temps are in control, then detach all system peripherals, like RAM / GPU and clean the slots then reattach them to see if that helps or not
even after cleaning the dust if the issue is still on, then try and borrow a compatible PSU from a friend of yours and try with that, see if you are able do normal operation or not !!!
RAM Issue
once again, borrow some ram from a friend of urs to see if the issue is still on or not !!!
Update the BIOS and then reset it to default use BIOS option of jumper for ressting now install the trial version of a good AVS, such as ESET NOD 32 or KIS 2009, update and run a full system scan (scan all HDD drive and partitions) to see if any infection of not
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 25-08-2008, 11:09 AM   #6 (permalink)
M3TAL H3AD M3
skippednote's Avatar
I think something might have Affected your Hardware
check your RAM as well as SMPS
I spit Rainbows.
skippednote is offline
Old 25-08-2008, 01:13 PM   #7 (permalink)
Stay Silent!
enticer86's Avatar
* System Temp
* RAM Issue
1. Sys temp is within limits.- at 46.C
2.No hardware issues.
3. No PSU/RAM issue- got my computer upgraded on 11th July'08 only
4. MALWARE- i guess some virus file which copied itself to all partitions. I deleted all the partitions, recreated and resized them. And now the system is alrite.
How do I clear the MFT space? there was no MFT space reserved last month - the partitions were NTFS but no mft.
I saw me running,
Old 25-08-2008, 01:30 PM   #8 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
@Choto Cheeta ...... superb explaination frd .......
@enticer86 ..... its definately RAM problem ...... it doesnt matter if its new or old ....... just check it 1`s ...... clean it & fix it again properly ........
... W H O T ...
ax3 is offline
Old 25-08-2008, 01:31 PM   #9 (permalink)
Rebooting
How can you be sure as new hardware can also give you problem man , so please do check, its not that we are argueeing but rather trying to find a sol for your problem, so please if possible do check them with another one from your frnd or such !!!
anyway,
Can I adjust some master NTFS table size
rebooting
ChotoCheeta.com
Old 25-08-2008, 01:32 PM   #10 (permalink)
Elevating Humanity
The Conqueror's Avatar
@Choto Cheeta : WOW, Excellent Explaination..
@enticer86: Try Cleaning the fan,RAM etc.
Regards,
The Conqueror
The Conqueror is offline
Old 25-08-2008, 05:34 PM   #11 (permalink)
Stay Silent!
enticer86's Avatar
Thanks for your detailed help bro, but I do not have anyone geeky enough to lemme check the PSU. Will take the machine to the seller again (he is a relative, so would be honored to help )
And I know buddy, you are not arguing thanks indeed for helping out of he way. I also thought abt the RAM issues, and cleaned it and put it back again tighly
I saw me running,
WinXp installation problem? marulez Software Q&A 2 01-04-2007 02:05 AM
Help urgent winXP installation himtuna Software Q&A 10 05-03-2006 07:52 PM
Adobe Photoshop 6 installation problem in winXP Nimtshey Software Q&A 2 04-12-2005 12:10 AM
WinXP Pro Unattended Installation debopriyo Software Q&A 5 11-02-2005 05:40 PM
WinXP SP2 Installation Advisable OR NOT dikudik Software Q&A 2 06-12-2004 03:45 PM
- by Niilesh
