Old 22-08-2008, 08:59 AM   #1 (permalink)
Default nokia pc suite problem
i had installed nokiapc suite in my system for using one of my frnds cell.
after use i uninstalled it.
but the shortcut"nokia phone browser" at my computer remains without any icon.
hw can i remove that?no delete option isthere...only open/explore(nothing to open or explore) is there and create shortcut can be found by rightclicking
snehangshu is offline
Old 22-08-2008, 10:13 AM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: nokia pc suite problem
Did u intstalled the latest version of it...i.e 6.86.XXX ..its good version now
Zangetsu is offline
Old 22-08-2008, 10:52 AM   #3 (permalink)
Amir.php's Avatar
Try to delete with unlocker:
http://www.majorgeeks.com/Unlocker_d4660.html
Amir.php is offline
Old 22-08-2008, 11:38 AM   #4 (permalink)
Elevating Humanity
The Conqueror's Avatar
Try to Clean the Invalid Registry Entries and Shortcuts.TuneUp Utilities 2008 has an option to do this job.
Regards,
The Conqueror
The Conqueror is offline
Old 22-08-2008, 04:44 PM   #5 (permalink)
registry cleaned with ccleaner.
now noname but an unused icon stays unnecessarily
Old 22-08-2008, 08:37 PM   #6 (permalink)
Elevating Humanity
Have u Cleaned invalid shortcuts using tuneup?
Get a free trial version from here -> http://www.tune-up.com/download/tu2007/
and do 1 click maintenance
Regards,
The Conqueror
Nokia PC Suite problem adi007 Buying Advice 7 11-08-2008 07:18 PM
Nokia Pc Suite problem phuchungbhutia Buying Advice 1 31-03-2008 07:59 PM
Nokia PC Suite Problem !!!! dreams Software Q&A 5 17-07-2007 10:10 AM
Nokia PC Suite Bluetooth Problem cryptid Buying Advice 4 25-01-2006 12:40 AM
- by Niilesh
