Old 20-08-2008, 06:09 PM   #1 (permalink)
Default how to restrict installation
hi guys i want to restrict the installation of all the softwares
through some software
can you peoples suggest some thing
i know this can be done by creating an guest account but i want one software so plz suggest me one free software
balajiaslp is offline
Old 20-08-2008, 07:41 PM   #2 (permalink)
Elevating Humanity
The Conqueror's Avatar
Default Re: how to restrict installation
You can create a limited user account
Regards,
The Conqueror
The Conqueror is offline
Old 20-08-2008, 10:30 PM   #3 (permalink)
AFK
thewisecrab's Avatar
Creating an account with limited administrative rights is most recommended
not aware if a software is available for your need,
but to create a limited account, check this out:
http://www.microsoft.com/windowsxp/u.../accounts.mspx
Check out http://thefinal3rd.com, an Indian footie blog. Follow me on http://twitter.com/thewisecrab
Fishdumplings!! Duniya goal hai?
thewisecrab is offline
Restrict User in VISTA naveen_reloaded Software Q&A 12 03-11-2007 10:21 PM
How to Restrict Download??? sauravktr Software Q&A 3 28-08-2007 07:44 PM
restrict net for user larsan Software Q&A 1 17-04-2007 03:38 PM
restrict printer use using password? hansraj Peripherals 3 30-07-2006 02:24 AM
how to restrict downloads trigger Internet & WWW 2 24-09-2005 10:25 PM
