Old 18-08-2008, 10:30 PM   #1 (permalink)
Unhappy Vista Explorer Problem
i m using Vista 32 bit since last 1 year. i found explorer problem last week and i need a your help to solve the problem. when i try to open my C drive, i m getting the message "window explorer is stop working" and explorer automatically get closed. it happens to D drive also and i scan both the drive, on D drive problem is solved but problem is still there on C drive. i had run virus scan, boot scan but could not found anything.
Kindly suggest the solution.
lucky387 is offline
Old 19-08-2008, 10:56 AM   #2 (permalink)
The Frozen Nova
casanova's Avatar
Default Re: Vista Explorer Problem
I guess this happens when a virus corrupts some file/folder. As your explorer is crashing as soon as open your C drive, the corrupted file/folder should most probably be sitting atop your c drive.
Open up your command prompt and do the directory listing there, in case you find some unwanted file/folder, remove it. This should solve your problem.
Alternatively, you can download some third party explorer for analyzing.
www.nerdweed.blogspot.com
casanova is offline
How to get vista explorer in xp? New Software Q&A 11 22-10-2007 09:41 AM
Fast Explorer for Vista. anandk Software Q&A 1 02-07-2007 06:33 PM
Internet Explorer in Vista pantheratigris Software Q&A 1 16-04-2007 04:07 PM
explorer exploder in Vista Dumbledore Software Q&A 7 14-10-2006 09:27 PM
