Old 16-08-2008, 08:20 AM   #1 (permalink)
Default Pls help For Nlite
Hai all out there
can someone Guides me to use Nlite. i don't know how to add softwares in it
pls some one tells me i will be very thankful to you guys. pls help me
stars4lucky is offline
Old 16-08-2008, 08:32 AM   #2 (permalink)
Amir.php's Avatar
Default Re: Pls help For Nlite
Best tutorial is here:
http://www.winaddons.com/nlite-14-tutorial/
Amir.php is offline
Old 16-08-2008, 08:59 AM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
And if you have more questions, you should visit msfn.org forums. They are have the best resources and solutions for customizing OS installs
dheeraj_kumar is offline
Old 16-08-2008, 12:53 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Is there a guide to registry tweaker?
comp@ddict is offline
Old 17-08-2008, 09:57 AM   #5 (permalink)
http://unattended.msfn.org/unattende...list/registry/
A partial list.
Autopatcher from www.autopatcher.com has more.
nLite ! ! ! ax3 QnA (read only) 15 24-10-2007 04:24 PM
Problem with NLite janitha Software Q&A 2 16-07-2007 04:56 PM
nLite 1.3 Final alsiladka Technology News 9 06-03-2007 10:51 AM
How 2 use nLite???????????? Naveed Software Q&A 1 26-01-2007 03:08 AM
nLite Users for Slipstreaming help khandu QnA (read only) 1 18-08-2004 03:11 AM
