Old 15-08-2008, 10:55 PM   #1 (permalink)
din
Tribal Boy
din's Avatar
Default Please suggest a light weight CD/ DVD burning software
As the title says ..
I was using Nero (came with the burner) but taking a lot of resources.
Then I got portable infrarecorder, works great except for
CD to CD / DVD to DVD (source and destination same).
Any free + light weight + portable(preferred) burning software ? Need support for disc to disc copy.
din is offline
Old 15-08-2008, 10:57 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: Please suggest a light weight CD/ DVD burning software
burnCDCC (its the best lite weight burner) i used it eventhough i hv got nero 7 but was really happy with the burning, use it u wont be disappointed believe me or use iso burner
cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 15-08-2008, 10:58 PM   #3 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
CDBurner XP should do the trick.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is online now
Old 15-08-2008, 11:04 PM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
ImgBurn
kalpik is offline
Old 16-08-2008, 01:50 AM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
I posted it in the "cleaning up trash" thread. First uninstall nero if you already have it, and reinstall, but in the installation options, untick everything except startsmart, express, and burning rom. That makes the install take only 146 MB, and burning takes around 45-50 MB in memory. Not exactly lightweight, but compared to the highly bloated 1 gig install and 100 mb memory it takes regularly, its better like this. Since nero is one of the best burners feature-wise, I guess this one's better than others suggested here Try it.
dheeraj_kumar is offline
Old 16-08-2008, 01:58 AM   #6 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Best writing soft i hav used is Nero Lite
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 16-08-2008, 03:15 AM   #7 (permalink)
Lets Do It!
amrawtanshx's Avatar
Ya.. I do it this way.
If you use all its features then it takes more than 200MB in my case.
So using only StartSmart is the better.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 16-08-2008, 03:24 AM   #8 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: Please suggest a light weight CD/ DVD burning software
i do same as dheeraj_kumar or u can use powerISO
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 16-08-2008, 07:54 AM   #9 (permalink)
My preferences are CD Burner XP Pro and Deep Burner
Arun
sakumar79 is online now
Old 16-08-2008, 11:37 AM   #10 (permalink)
GaurishSharma.com
gary4gar's Avatar
Try Nero Micro - Nero on Steroids.
Its a Stripped down version it includes
* Nero Burning ROM
* Nero Express
It leaves out everything else.
so its quite fast & responsive
gary4gar is offline
Old 18-08-2008, 11:32 PM   #11 (permalink)
din
Tribal Boy
din's Avatar
Thanks a lot for the suggestions friends.
I tried almost all softwares listed by you. Really nice ones.
For simple use (like data disks, image burn etc), I still prefer Infrarecorder, only drawback I can see is the one mentioned before, I mean Disk to Disk copy is missing. Other than that, it is nice - simple and small.
din is offline
Old 18-08-2008, 11:37 PM   #12 (permalink)
clmlbx's Avatar
* Nero Burning ROM
* Nero Express
+1
using this with no problem .
or you can also go for Nero Lite
  • Nero Burning Rom (with VideoCD Support and MauSau Audio Plug-ins)
  • Nero Express
  • Nero CoverDesigner
  • Nero WaveEditor
  • Nero Toolkit
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now
Old 18-08-2008, 11:37 PM   #13 (permalink)
Elevating Humanity
The Conqueror's Avatar
Have you Tried Ashampoo? If I remember correctly , this was given several times in Digit DVDs
Regards,
The Conqueror
The Conqueror is offline
Old 19-08-2008, 12:56 AM   #14 (permalink)
The High 5 Flyer
sam9s's Avatar
+1 for Ashampoo. Its very light, clean menu navigation and hasnt made an DVD useless with any burning errors.....yet. A must try I would say.
sam9s is offline
Old 19-08-2008, 01:14 AM   #15 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
+1 for nero micro/nero portable
jin files ka koi server nahi hota unka bittorrent hota hai
chesss is offline
Old 19-08-2008, 01:46 AM   #16 (permalink)
Smitten by Computers..
raptorz's Avatar
ImgBurn is the best. Ultralight and tons of options.
There were somethings Man was never supposed to know, for everything else there is Google..
raptorz is offline
Old 19-08-2008, 07:23 AM   #17 (permalink)
Cool G5's Avatar
Yup try Ashampoo. Light & hassle free.
Cool G5 is offline
Old 19-08-2008, 08:28 AM   #18 (permalink)
kumarmohit's Avatar
Ashampoo is the best option and if you have not got the Digit disc version, they give version 6.5 for free.
kumarmohit is offline
Old 19-08-2008, 09:48 AM   #19 (permalink)
adi007's Avatar
Ashampoo for windows
k3b for linux
infrarecoder is also nice
doiteasily.com ►easy way(s) to do certain things
Tech Word of the day : ADSL
Aditech Blog ► There is something for everyone
Terminal Command of the day
regtweak.info ► Windows Registry hacks and tricks
adi007 is offline
Old 19-08-2008, 10:29 AM   #20 (permalink)
The Frozen Nova
casanova's Avatar
Ashampoo is a very nice burner. I guess version 7 is available for free as well. Version 8 is the latest.
www.nerdweed.blogspot.com
casanova is offline
Old 19-08-2008, 12:31 PM   #21 (permalink)
Violent serenity.
Psychosocial's Avatar
CDBurnerXP ftw ..........
Psychosocial is offline
Old 19-08-2008, 12:38 PM   #22 (permalink)
GaurishSharma.com
gary4gar's Avatar
k3b for linux
Do you know whats the full form of k3b ?
gary4gar is offline
Old 19-08-2008, 04:12 PM   #23 (permalink)
Elevating Humanity
^What is it?
Regards,
The Conqueror
Old 19-08-2008, 04:53 PM   #24 (permalink)
din
Tribal Boy
din's Avatar
Burn Baby Burn !!! lol thats funny.
din is offline
Old 19-08-2008, 05:22 PM   #25 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
K3b is a light and easy cd/dvd burner for linux.
I think cdburner xp is pretty good.. But i use my bundled cd/dvd authoring software..
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline
Old 19-08-2008, 05:30 PM   #26 (permalink)
adi007's Avatar
Yup that's rite
Even i was amazed when i first came to know about the full form "KDE Burn Baby Burn"
adi007 is offline
Old 21-08-2008, 01:56 AM   #27 (permalink)
Me 2 do the same thing. There is no need of all other component. Installing everything from package just because we paid for the copy is idiotic.
Install only those component which u really need n use.
jamsus is offline
Old 21-08-2008, 07:08 PM   #28 (permalink)
din
Tribal Boy
din's Avatar
Actually memory and HDD space usage was one thing and next thing was - portable. As I mentioned before infrarecorder was working fine for this except the other point I mentioned. On google search, I got a link to Ashampoo portable, but not sure whether its official / legal.
Also, how to make sure it is really portable. I mean when I tried, it didn't install anything, just an exe file, but any registry entries ? How to check that ?
din is offline
Old 21-08-2008, 08:55 PM   #29 (permalink)
Elevating Humanity
You Can check for registry entries manually by Start>Run>Regedit , and then search for your product in HKEYlocalmachine softwares or something..Ask Vishal he is registry expert .
Best way to check is look at the download link, if it is from ashampoo.com then its official!
And Legal
Regards,
The Conqueror
Last edited by The Conqueror; 21-08-2008 at 08:55 PM. Reason: Automerged Doublepost
Need light weight Multiplayer games to play through Internet... Ganeshkumar Gamerz 10 22-03-2008 06:56 AM
DVD,CD burning software JohnephSi Software Q&A 8 26-09-2007 06:16 PM
Light weight Nokia s60 ? any suggestions ? esumitkumar Buying Advice 14 09-08-2007 10:16 AM
install thunar: a light weight file manager on gnome infra_red_dude Open Source 8 04-08-2007 03:01 PM
Suggest a good Burning Program navjotjsingh QnA (read only) 25 19-05-2005 12:57 PM
- by Niilesh
