Old 14-08-2008, 05:31 PM   #1 (permalink)
rohitshubham's Avatar
Arrow very slow speed of net
hi
i am using sify broadband rs250 scheme which provides me 128kbps speed but when i download anything the speed is mere 10 to 15 kbps. but the other users have sufficient speed(nearly 100kbps).
so what could be the problem?is it my computer??
rohitshubham is offline
Old 14-08-2008, 05:38 PM   #2 (permalink)
kumarmohit's Avatar
Default Re: very slow speed of net
Dude did you check the kbps and KBps thing? The capital B and Small b... they are Bytes and bits.
kumarmohit is offline
Old 14-08-2008, 08:31 PM   #3 (permalink)
hi
i second wat he said...plus....your download speed cant exceed one eighth of your internet connection speed...
as far as i kno (afaik)
regards
Regards
imageek is offline
Old 14-08-2008, 09:10 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Hi. If your plan is a 128"kbps", then you are getting the speed that you can max. avail i.e. 10-15 kb/s download speed. I'm suprised u'r getting up2 15 at least, my friend with the same plan never exceeded 13.5
comp@ddict is offline
Old 16-08-2008, 09:36 AM   #5 (permalink)
Tich tor ang tesmur
you dont post that under Software Troubleshooting, put it under i-got-lucky-as-hell !
boom2709 is offline
Old 16-08-2008, 01:42 PM   #6 (permalink)
stellar's Avatar
I'm using 128 kbps adsl and that's the download u get in that scheme. It's the right kind of download speed there's nothing to worry about. I get upto 16 kbps.
stellar is offline
Old 17-08-2008, 01:01 PM   #7 (permalink)
Violent serenity.
Psychosocial's Avatar
128 / 8 = 16
So ,16KB/s is the max that you will get.
Psychosocial is offline
slow speed william QnA (read only) 10 03-03-2006 10:20 PM
Slow Speed Internet kumarn_2004 Internet & WWW 5 12-12-2005 02:31 AM
write speed slow nishant_garg89 QnA (read only) 5 30-10-2005 07:27 PM
Pc speed is too slow sunil02 QnA (read only) 17 11-02-2005 08:52 PM
- by gforz
- by Piyush
