Old 14-08-2008, 04:36 PM   #1 (permalink)
ajooba215's Avatar
Default drives not opening..
Hey fellas..seems like ma pc will never work perfect..this time its the drives..except the 'c' drive..which contains system files...no other drive is opening..one of them gives a 'don't send' error and others flash a ms-dos window for a mili second..what can be the prob?...mentioning..i've recently established a lan connection recently and ve installed a lan card too and got this error after that..
Y FOLLOW WHEN YOU CAN LEAD.....
ajooba215 is offline
Old 14-08-2008, 04:40 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Default Re: drives not opening..
Wow!!!
U sure do got infected by some virus
Scan ur PC.................and to open those drives right click and select Open, got to Folder options and mark view hidden files and mark view system files too.
When double clicking upon drives opening a MS-Dos windows means, theres sure an autorun file which is causing the problem.
If my diagnosis is verified by u, I'll tell u wat to do next.
u can refer this thread
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 14-08-2008, 08:09 PM   #3 (permalink)
ajooba215's Avatar
dude....i m able to open the drives by clicking open after right clicking on the drive...and as u told...i marked view hidden and system files...and i m afraid..it didn`t make any diff....and as far as virus or spyware is concerned ..i`ve tried my best by updating the suite and scanning the whole system...i think i`ll have format those drives...is there any way of getting out of it???,...
Old 14-08-2008, 11:30 PM   #4 (permalink)
Wandering In Tecno Land
Ecko's Avatar
You are 1000% infected with virus
Download latest Avast antivirus & put ur PC for a boot time scan (as you see the dos window means something is still executing )
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 17-08-2008, 01:31 PM   #5 (permalink)
Boom Boom Boom
cooldudie3's Avatar
First, scan your computer with NOD32 or Kaspersky Anti Virus. Disinfect any files they find. Reboot, and then reboot again. Try to open the drive again. If that doesn't work, maybe the autorun file is corrupted.
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
Old 18-08-2008, 09:44 PM   #6 (permalink)
Beta Waves's Avatar
For the hidden files problem. Look at the 22nd question here
[Windows] FreQuently AsKed ProBlems WITH SoluTions...
I am Back....
Beta Waves is offline
Old 25-09-2008, 06:29 PM   #7 (permalink)
ajooba215's Avatar
it ain`t working...tried everything...the only way to open drives now is to navigate through the address bar..and thas s*cking...i know...i can format thesed drives but i want the right way to fix it....
Old 25-09-2008, 07:09 PM   #8 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
start->run "cmd"
go to each drive, type "del autorun.inf"
Repeat in all drives.
Run NOD32 and Spybot Search n Destroy to clean your comp.
dheeraj_kumar is offline
Old 25-09-2008, 08:10 PM   #9 (permalink)
Wise Old Mouse
mrintech's Avatar
This problem gets arises when you insert Pen Drive on your PC. This was the case with me some days back but it automatically gone
BTW also scan your pc with the software combination from here: http://tech-baby.co.cc/2008/09/13/be...or-home-users/
Especially a-squared and spyware terminator
Hope it helps
cheers!!
- MrinTech :)
mrintech is offline
Old 27-09-2008, 10:33 PM   #10 (permalink)
ajooba215's Avatar
hey dheeraj..ur suggestion worked...thanx a lot...at least i can fix this whenever it troubles me....thanx again...
Old 28-09-2008, 07:03 AM   #11 (permalink)
paroh's Avatar
install usb Disk security
paroh is offline
Old 28-09-2008, 08:51 AM   #12 (permalink)
Wise Old Mouse
mrintech's Avatar
^^^ problem already fixed
- MrinTech :)
mrintech is offline
Drives not opening sravan Software Q&A 2 21-03-2008 05:25 PM
Drives Are Not Opening smile Hardware Q&A 3 12-11-2007 06:23 PM
Drives Are Not Opening smile Software Q&A 2 11-11-2007 11:26 PM
Drives Are Not Opening smile Software Q&A 3 09-11-2007 10:07 PM
drives not opening sharma_atul85 QnA (read only) 4 25-03-2007 10:35 PM
- by gforz
- by Piyush
