Old 14-08-2008, 04:07 PM   #1 (permalink)
Unhappy HELP guyz need help
hey guys i have encountered a big problem whenever i double click my computer icon it open the properties of it. help its urgent.
kushagra1993 is offline
Old 14-08-2008, 04:13 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Default Re: HELP guyz need help
Does this happen in every boot or it happened in this log-on only??
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 14-08-2008, 04:17 PM   #3 (permalink)
i just now installed a fresh copy and had rebooted many times but the problem occurs.
Old 14-08-2008, 04:19 PM   #4 (permalink)
Democracy is a myth
rhitwick's Avatar
Have you any antivirus installed, if not download Avira trial version and Ad-Aware free version.
Install, go offline and do full scan.........
Old 14-08-2008, 04:21 PM   #5 (permalink)
it has got mcafee antivirus fully updated
and i just now formatted the hd
Old 14-08-2008, 04:24 PM   #6 (permalink)
Democracy is a myth
rhitwick's Avatar
Buddy then one thing I can tell u
Try these:- Source Yahoo answers)
Click START, then RUN and type in CMD, and click on OK.
When the Command Prompt appears, type "C:" and hit ENTER.
Type "CD\" and hit ENTER.
Type "ATTRIB -S -R -H -A AUTORUN.INF", and hit ENTER.
Type in "DEL /F /Q AUTORUN.INF".
Reboot your pc.
Try to double click your drive now.
(All the typing is done WITHOUT " ")
OR
Try one of these:
01.) run this in your run box or command prompt:
regsvr32 /i shell32.dll
02.) http://wiki.answers.com/Q/When_you_doubl...
03.) http://www.daniweb.com/forums/thread6873...
04.) http://forum.soft32.com/windows/drive-op...
05.) http://www.softwaretipsandtricks.com/for...
06.) http://forum.notebookreview.com/showthre...
Old 14-08-2008, 04:32 PM   #7 (permalink)
thNKS IT worked
Old 14-08-2008, 04:34 PM   #8 (permalink)
Democracy is a myth
rhitwick's Avatar
may I know where r u from?
Old 18-08-2008, 01:06 AM   #9 (permalink)
Dear sir,
thanking you very much. letme too try. and also, sometime, the same problem arising while inserting PEN DRIVE. how can i solve this too??
be kind to guide
thanking you in advance
smobileman
mobileman is offline
Old 18-08-2008, 01:31 AM   #10 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: HELP guyz need help
Originally Posted by mobileman View Post
Dear sir,
I'm not used to these
sometime, the same problem arising while inserting PEN DRIVE. how can i solve this too??to guide
thank
Wat?? Wat do u tell?? Sam problem in Pen Drive??
Beware..................it surely infected....................Don't open it by double clicking the drive............open by Right Clicking...........I say don't open it.............
Do virus scan by Kaspersky or Avira AntiVir...........remember to update b4 scanning...........
Its very annoying virus I guess ur PC is already infected................do a antivirus scan of ur PC and remeber to scan any............ANY pen drives b4 using.........
Best of luck
Old 18-08-2008, 07:02 AM   #11 (permalink)
hi thanking you,
and as a stranger you are to me,where we dont know anything abt US. i may call you sir with respect. simply
and see, i am using a Avast with daily gets updated.and when i am scanning my pendrive, it scanning and nothing sowing. still, some times, while connecting and trying to open means showing "OEN WITH", but the most important thing is that, while detecting the pendrive, i am getting the auto detection and will ask i need to open as forder or with any app, as usual. but on the double click to open direct means, mislead to OPEN WITH.
hope you have got cleared more
waiting
lovingly
mobileman
Old 18-08-2008, 05:52 PM   #12 (permalink)
Democracy is a myth
rhitwick's Avatar
ur Pen Drive is infected and I've no doubt on that............I was a victim of d same.........
Scan ur Pen Drive with Kaspersky or Avira
And follow method in Post6 to find any "Autorun.inf" file in d drive...........
if found delete it..................
need help guyz !!!!!!!! crazypal24x7 Mobiles and Tablets 28 22-01-2008 01:39 PM
GOOGLE Ads not seen in my PC :( (help me guyz) tinku dhar Internet & WWW 3 21-09-2007 11:10 PM
Gpu- Guyz Please Help Urgent! iamitp Graphic cards 11 14-04-2007 09:10 PM
Guyz tell me the prices of ............. divyadbzgt1 QnA (read only) 10 05-08-2005 04:34 PM
--HELP NEEDED GUYZ jamifahad Gamerz 9 28-05-2005 05:24 PM
- by gforz
- by Piyush
