Old 13-08-2008, 11:22 AM   #1 (permalink)
saurabh.sauron's Avatar
Default Infected Pen Drive
My USB Pen Drive has been infected badly. I am unable to see any folders but can access them. I checked on the internet and found that it was the kinza virus which has infected my pen drive. my computer is safe but how can i get back my folders?
pls help
thnx
UPDATE: I guess I solved my problem. I unchecked Hide Known Extension. I am able to see the folders now but they are hidden folders and i cant find a way to unhide them.
saurabh.sauron is offline
Old 13-08-2008, 11:44 AM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Infected Pen Drive
what u said u can access..but cant see the folders How Come ???
if they r in fade color dat means they r hidden...just ryt click the folder > properties >
uncheck Hide checkbox....
Zangetsu is offline
Old 13-08-2008, 11:47 AM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
its infected with a virus probably autorun.inf or sumthing of that sort, also, never allow ur pendrive to autorun also, never OPEN ur pendrive directly (by double clicking on it in My Computer) as this activates the autorun.inf virus and causes all the folders to either being named as "NEW FOLDER" or attach extensions to every doc as ".exe"
so, always EXPLORER ur pendrive to open it by clicking on windows icon+E (from the keyboard)
wat antivirus u use ?? if its NOD32 then it will detect the viruses in the pendrive and remove it automatically...
Cheers n e-peace.....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Infected? Anindya QnA (read only) 2 13-12-2007 06:51 PM
If I'm Infected or something Ecko QnA (read only) 4 26-11-2007 10:18 PM
Infected .... :( vineetrocks2005 QnA (read only) 12 11-06-2007 06:07 PM
Please Help .. I am Infected. MambaXL Software Q&A 10 13-02-2007 01:48 PM
help me my pc is infected bholu Software Q&A 11 22-01-2006 11:00 AM
- by gforz
- by Piyush
