Old 12-08-2008, 09:47 PM   #1 (permalink)
clmlbx's Avatar
Question any difference between 1080p video and dvd watching on a normal 17 inch samsung crt ?
any difference between 1080p video and dvd ,watching on a normal 17 inch samsung crt ?
if i watch 1080p on a my 17 inch samsung crt will it be better then dvd quality ?
as my monitor is not hd ?
means technically and can i see the difference in quality
my system is capable of playing video 1080p but not my monitor (not hd)?
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now
Old 13-08-2008, 07:13 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: any difference between 1080p video and dvd watching on a normal 17 inch samsung c
There would be no difference between 1080p and 720p, but there will be a hell lot of difference between a DVD and a 720p HD
kalpik is offline
Old 13-08-2008, 07:38 AM   #3 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
no difference.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 13-08-2008, 09:08 AM   #4 (permalink)
Edburg's Avatar
your monitor can support a max of 720p (1280 x 720 ) only.....DVD is only 640 x something VGA resolution...
so u can see a big difference with 720p...even 1080p will be displayed only as 720p in ur monitor...so better to get 720p for ur system as its low size
Edburg is offline
Old 13-08-2008, 10:31 AM   #5 (permalink)
clmlbx's Avatar
my monitor is not hd .then too i will get the difference ?
at present i am running at 1280 x 1024 resolution...
if yes , means my monitor is capable of running 720p hd videos in it true quality as it will play in hd monitor .......or just it will play better the dvd .
Old 13-08-2008, 11:02 AM   #6 (permalink)
Edburg's Avatar
yes ur monitor will perfectly display upto 720p quality videos...higher than that though ur system supports it,ur monitor wont be able to display them...
dvds have crappy quality compared to these..
just that on a 17" CRT..u'll have a large screen wastage due to wide screen formats of HD...
btw...i too am having same display and full HD capable system
Edburg is offline
Old 13-08-2008, 12:19 PM   #7 (permalink)
ajayritik's Avatar
Even I have a CRT but 15" so would I be able to make a difference between DVD and 720p. Of course my desktop has all the configuration to play HD stuff like RAM etc. I'm not sure whether I will be able to notice the difference between the two. Please give me some more info on this.
ajayritik is online now
Old 13-08-2008, 02:41 PM   #8 (permalink)
clmlbx's Avatar
ok so u want to say that hd monitors are just with high resolution display and no diffrence with normal or say my monitor
Old 13-08-2008, 03:49 PM   #9 (permalink)
kalpik's Avatar
Yes.
http://en.wikipedia.org/wiki/Image:C...olutions_2.svg
kalpik is offline
Old 13-08-2008, 03:53 PM   #10 (permalink)
Edburg's Avatar
yeah of course....thats what is all about HD buddy - the high resolution
and u have to have good contrast,response time and of course good sound output to enjoy all that along with higher resolution
@ajay...you can play videos upto the max resolution supported by ur monitor...more than that your display wont see any difference at all
so u can very well see difference in ur display too
Edburg is offline
Old 13-08-2008, 04:15 PM   #11 (permalink)
ajayritik's Avatar
Dude I remember reading in another thread that it wouldn't be able to notice that much difference for this kind of resolution. So I was wondering whether its really worth the difference between a normal DVD and 720p. Will the difference be noticeable? My friend has couple of movies with him with that resolution but I was wondering if it's really worth it coz that's gonna take lot of space of my HDD.
Old 13-08-2008, 05:35 PM   #12 (permalink)
Lets Do It!
amrawtanshx's Avatar
Hey ..
The difference is very viable to naked eyes.
Just compare once.Its enough.
Even on my 17" there's a lotsa difference.But it hogs lots of space.
U pay for that clarity.Dont u ????
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 13-08-2008, 09:15 PM   #13 (permalink)
clmlbx's Avatar
thanx a lott guys for clearing my doubts
Old 13-08-2008, 09:51 PM   #14 (permalink)
Edburg's Avatar
you guys can download a sample few secs HD video (do a google search) and play it to really see if you would like them or stick with dvd(which is highly unlikely)
Edburg is offline
Old 13-08-2008, 09:55 PM   #15 (permalink)
clmlbx's Avatar
what about my philips 21 inch television .
how to know about that ?
as I don't know what resolution it displays .
what is difference between 720p and 720i
Old 13-08-2008, 10:46 PM   #16 (permalink)
 Macboy
goobimama's Avatar
Not read the complete thread, but it will be guaranteed no difference. I mean, apart from counting the pixels, you won't see any quality difference. You might see difference if you zoom into a widescreen video. But that is only upto 720p. 1080p you can forget about.
I'm like a bird... :)
goobimama is offline
Old 13-08-2008, 11:41 PM   #17 (permalink)
GaurishSharma.com
gary4gar's Avatar
there is a huge diff between DVD and 720p clips. but not much diff between 720p and 1080p clips on a 17" CRT display. 108p is more suited for larger displays upwards from 22"
gary4gar is offline
Old 14-08-2008, 04:16 AM   #18 (permalink)
 Macboy
goobimama's Avatar
Here's a little chart that should help you decide on what exactly makes the difference when it comes to HD.
Old 14-08-2008, 05:54 AM   #19 (permalink)
kalpik's Avatar
TV Resolution is 720x480. So HD vs DVD would not be THAT visible on a TV.
kalpik is offline
Old 14-08-2008, 09:27 AM   #20 (permalink)
ajayritik's Avatar
Originally Posted by amrawtanshx View Post
Hey ..
Dude I didnt understand your statement where you mention difference is very viable to naked eyes. Can you elaborate further? Even goobimama is telling the same thing as I had mentioned that there is no clear difference
Old 14-08-2008, 09:45 AM   #21 (permalink)
kalpik's Avatar
^^ Im sure goobi was referring to 1080p vs 720p and amrawtanshx was talking about 720p vs DVD
kalpik is offline
Old 14-08-2008, 10:11 AM   #22 (permalink)
ajayritik's Avatar
I have watched the Elephant's dream and some movie trailers in HD. It definitely looked better than normal DVD especially Elephant's dream but I have not yet watched a full length HD movie on my PC. Maybe I should try watching a movie then I will know.
Old 14-08-2008, 10:52 AM   #23 (permalink)
Lets Do It!
Yes I was talking about 720p vs. DVD.
I have a few 720p and DVD videos .... On comparing there was hell of a difference.
And 720p was way better.
Just checkout few of the .mkv songs(HD ones) ... They are always better than DVDRIPS.
I also checked out 1080p on my 17" ...
But the quality was not noticeable.
But the same videos looked fantastic on my friend's Samsung 19" one.
Old 14-08-2008, 11:38 AM   #24 (permalink)
clmlbx's Avatar
thanx too all of you, and Happy to know that my 8 years old monitor can play 720p HD videos.
Old 14-08-2008, 09:04 PM   #25 (permalink)
Lets Do It!
Surely it can.
8 years old.
I thought in 2000's 15" was only available.
What's the difference between a normal blank CD and CD's given magazines,etc.... Ray Networking 9 19-12-2006 12:22 PM
19 inch LCD monitors.(Widescreen and Normal) I Do Not Have A Username. Hardware Q&A 22 13-12-2006 12:17 AM
Difference in Compressed Disk Image (DAA) & Normal ISO??? go4saket QnA (read only) 6 18-08-2006 12:07 AM
Difference between Celeron and Normal Pentium nawaz123 Hardware Q&A 3 07-03-2006 04:18 PM
- by gforz
- by Piyush
