Old 12-08-2008, 10:03 AM   #1 (permalink)
 Macboy
goobimama's Avatar
Default Need some DOS help
Here's the scenario. A DOS program needs to be run, and print out invoices. So far it has worked as a nice dual boot system. XP on one end, and Win98 with its core files missing so it automatically boots into DOS.
Now WinXP was recently reinstalled, and for some reason, the EPSON LX-80 printer (Wipro branded I think) refuses to print beyond a few lines (always the same amount of lines for a particular print). This has put me in quite a pickle as the running of that program is crucial. I tried printing a test page on the printer through XP and it works from there.
Now, is there a way by which I can use the Canon USB laser printer in DOS? Or maybe a way by which I can virtually print to a text file in DOS?
Here's hoping for some veteran geniuses still left in the forums.
Milind
Also, I noticed that one can install DOS. I've never really done this before, so how does one go about it?
I'm like a bird... :)
goobimama is offline
Old 12-08-2008, 03:08 PM   #2 (permalink)
Amir.php's Avatar
Lightbulb Re: Need some DOS help
goobimama, here you can find step by step:
http://http://geekswithblogs.net/dto...les/26204.aspx
http://http://www.computerhope.com/printhlp.htm
Amir.php is offline
Old 12-08-2008, 03:49 PM   #3 (permalink)
Default Re: Need some DOS help
@goobi, you can also use DOSBOX to emulate DOS mode...
Arun
sakumar79 is offline
Old 12-08-2008, 09:15 PM   #4 (permalink)
afonofa's Avatar
We use DOSPRN to print from dos programs in xp to a HP Laserjet USB printer.
afonofa is offline
Old 13-08-2008, 12:28 AM   #5 (permalink)
 Macboy
goobimama's Avatar
Thanks a lot. Will check those out when I get my net back.
Old 13-08-2008, 07:02 AM   #6 (permalink)
Amir.php's Avatar
Originally Posted by Amir.php View Post
These links are working now.
i have currect them.
Amir.php is offline
- by gforz
- by Piyush
