Old 08-08-2008, 09:41 AM   #1 (permalink)
Angry Local drive OPEN problem
Hi....
When double click on Local drive It will go to search option instead of opening local drive.
Can give solution????
sudharshan.panduranga is offline
Old 08-08-2008, 09:50 AM   #2 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Default Re: Local drive OPEN problem
If you mess around in the registry, or install some different software packages that add things to the right-click menu, you can end up with a problem where the default action on a folder is always "Search…", even though you set it to something else.
There's a quick and easy fix for this problem. Open up regedit.exe by using Start\Run and then browse down to this registry key:
HKEY_CLASSES_ROOT\Directory\shell
Double-click on the default value and set it to "none" without the quotes, as seen here:
This will restore the normal behavior.
If you are also experiencing this problem when you try to click on a drive, you can run this command from the run box or command prompt:regsvr32 /i shell32.dll
Source
I spit Rainbows.
skippednote is offline
Old 08-08-2008, 09:51 AM   #3 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Solution no 2
[Windows] FreQuently AsKed ProBlems WITH SoluTions...
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Local Area Network problem rhasta Software Q&A 3 16-07-2008 07:33 AM
cant open my d drive plz help avtarkaint Software Q&A 5 10-05-2008 12:59 PM
problem to open drive(ex. c:) patelviren QnA (read only) 3 13-11-2007 11:02 AM
Drive does not open....help plz sanphoe Software Q&A 6 24-04-2007 03:11 AM
- by gforz
- by Piyush
