Old 07-08-2008, 02:08 PM   #1 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Should I switch to Vista 64 bit?
I am currently using Windows Vista Ultimate 32 bit edition & my computer's hardware configuration is already known to many people here. I am about to upgrade to 3 GB RAM ( 1X2 GB & 1X1 GB DDR 2 800). Now 3 GB RAM will work fine with 32bit Windows but I was thinking that should I upgrade to 64bit edition of Vista? Will it give any performance benefit? I have checked compatibility & 90% of the apps & drivers I use are available in 64bit version & if not they can run in 32bit Mode.
Is there any speed & performance benefit going with 64bit vista when running with less then 4 GB RAM.?
about.me/gxsaurav
gxsaurav is offline
Old 07-08-2008, 02:40 PM   #2 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: Should I switch to Vista 64 bit?
You will get a definite 10~30% boost in in 64 bit apps,but driver problems are still der.
ok now answer my question
Shud i switch to windows vista 32 bit? frm xp sp3?
wt r the reasons other than security,dx10
My concerns abt vista r.....increased power usage,noise, HDD activity,n increaded cpu n gfx temps,sluggishness
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 07-08-2008, 04:30 PM   #3 (permalink)
gxsaurav's Avatar
I checked, I got 64bit drivers for all my hardware.
If XP works for u then no, else do it. You will like it.
Ease of Use, more response in OS.
These problems don't exist.
about.me/gxsaurav
gxsaurav is offline
Old 07-08-2008, 06:09 PM   #4 (permalink)
Right man in wrong place!
cyborg47's Avatar
my config is core2quad q9300, XFX nvidia nforce 780i,2X2GB ddr2, 500GB HDD, should i go for 64bit vista or 64bit XP....
Quad Core Q9300, Gigabyte EP45usb3 mobo, Zotac GTX 460 1024MB, 3x2 GB ddr3 memory, cooler master extreme 600W.
...They call me Prophet... - C2:twisted:
cyborg47 is offline
Old 07-08-2008, 08:01 PM   #5 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: Should I switch to Vista 64 bit?
As you got 4GB RAM then 32bit Vista is limiting the memory usage in your PC. Switch to 64bit after being sure that all of your PC components have proper 64bit drivers from their respective vendors.
debsuvra is offline
The Great Switch: Vista to Ubuntu (100%) Hitboxx Open Source 5 20-12-2007 05:21 PM
Vista SP1 kills the WGA kill switch Harvik780 Technology News 42 11-12-2007 11:52 PM
Is Windows Vista Worth The Switch? adit_sen Software Q&A 16 21-07-2007 08:25 PM
Windows Vista High Cost+kill switch= ???????? ankitsagwekar Technology News 2 12-10-2006 10:08 PM
A Vista kill switch would be good for Linux????????? ankitsagwekar Technology News 12 09-10-2006 04:23 PM
- by gforz
- by Piyush
