Old 03-08-2008, 07:25 PM   #1 (permalink)
Default File Sharing Problem inXP - URGENT
Hello,
I have toshiba laptop, it has genuine windows xp installed from cds came with it. The problem is that I need to share files form this machine on network.
I did simple file sharing, gave proper IP, enabled file sharing, disabled windows Firewall.
Created a folder and shared it.
NOw the strange thing is that I cann't access this system from any other system on LAN but from this system I can access any other system on lan.
I can ping from this system to any system on LAN but can't ping this system from LAN ie from other system.
What is the problem..
this is urgent .. ..
Please give all possible reason .. so that I can look into all..
Thanx
~Ricky
» Looking for someone to partner with me in Indian Linux forum
Free domain is available ! I am also at Indian Forums.
Ricky is online now
Old 03-08-2008, 10:13 PM   #2 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: File Sharing Problem inXP - URGENT
1. Search for computers by right clicking on My Network Places
2. or type the direct path in My Network Places address bar
for eg: \\computerName\folderName
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 05-08-2008, 09:57 AM   #3 (permalink)
Did you read what I asked in my post ?
Read again.....
Basically, this laptop is inaccessible from LAN but this laptop can access LAN easily.. what might be the issue ???
ANyONE ?
Anyways.. np.. I found it.. there was an inbuilt firewall installed with xp from Toshiba on laptop..
~Ricky
Ricky is online now
Old 05-08-2008, 01:44 PM   #4 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
yes,dude i just gave u possible solutions.
So da problem was with firewall ,and u asking me to read ur post again?
zyberboy is offline
Old 05-08-2008, 06:41 PM   #5 (permalink)
HI.....
Is the system that is unable to get access to system, asks for user name password to accesss your machine....................' then '
make a new connection on the system you havent made one on...if that doesnt work then make a new connection on the other one...
make new conn >setup a small home or office n/w >
when it asks for a method of connection... select "other" option the proceed , then "this computer belongs to a n/w that does not ahve an internet connection "
then fill up ur computer description ...now comes the most important part....
"turn on file and printer sharing" >> just finish the wizard
and restart your PC....
u might argue u have already done that...try doing this again.... it works
hope it does..that is how i make it work...
PS: try doing this on both th systems
Regards
imageek is offline
.doc file problem...please help..uRGENT windchimes Software Q&A 6 17-11-2007 10:40 AM
P2P FILE SHARING PROBLEM --- PLEASE HELP shersaha QnA (read only) 9 05-12-2005 01:59 PM
File and Printer Sharing Problem adeegee Peripherals 3 26-09-2005 05:54 PM
Fedora 3...file system check problem! URGENT HELP NEEDED! mediator Open Source 1 09-08-2005 06:52 PM
- by gforz
- by Piyush
