Old 02-08-2008, 11:28 PM   #1 (permalink)
Default log on problem
now i am using vista and windows xp pro. by default the system automatically log on to vista. is there i can change to older version of windows(xp pro)?
temperworld is offline
Old 03-08-2008, 02:36 AM   #2 (permalink)
Krazy_About_Technology's Avatar
Default Re: log on problem
Well, boot configuration in Windows Vista can be managed using a command line tool called BCDEdit. It comes with Windows and is present in the \Windows\System32 folder. First open an Admin Commannd prompt. To do that, open startmenu, in the searchbox type cmd.exe. When it appears on the list, right click on it and choose 'Run as Administrator', you'll get a UAC prompt if its enabled. Press Continue in it.
In the Admin Console, use the following command :
bcdedit /set {bootmgr} default "{ntldr}"
This should work on a default config. I am assuming that you have Windows XP and Vista installed in dual boot config on 2 different logical drives and no other OS (linux etc) is installed.
Reboot the system and you'll get Windows XP selected by default from now on.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 03-08-2008, 09:59 AM   #3 (permalink)
is it with space in between the words.
when i opened the commnd prompt it was written like this:
G:\Windows\system32>
when added ur commnd line with it as you have written here ( with sapce in between) , it says an unknown command was specified
now it did it without space in between the words, even then the same error.
Old 03-08-2008, 03:13 PM   #4 (permalink)
Amir.php's Avatar
here is a very simple method:
http://www.howtogeek.com/howto/windo...ual-boot-setup
Amir.php is offline
Old 09-08-2008, 10:03 PM   #5 (permalink)
Originally Posted by Amir.php View Post
it worked thanq
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by gforz
- by Piyush
